Door Buck in Double-Stud Wall
I have a few questions in regard to Rachel Wagner’s “Windows and doors in double-stud walls” article published here on GBA. I saw this question was raised back in 2019, but other than a suggestion to look at the article there was no further comment in that Q&A. I’m hoping to get a few more details from those who have used this approach.
Specifically, in what order is the “frame within a frame” constructed? Are the 2×4 jambs and heads making up the frame assembled to sections of 3/4″ plywood, and the plywood is then nailed to the 2×4 trimmers in the double stud wall? Is the polyiso insulation between the 2×4 frame members left out until the 3/4″ plywood has been nailed to the 2×4 trimmer of the exterior wall section? What prevents the 2×4 frame members from racking or twisting, especially where they meet at the top of the opening? (It seems that adding another section of 3/4″ plywood spanning those frame members would be good to add some rigidity there.)
Since I’ll be dealing with a framing crew that has possibly not done any double-stud wall construction I’d like to get all these details ironed out before construction starts. Any clarification would be greatly appreciated. Thanks!
Bumping this in the hope someone who's done "outie" doors in a double-stud wall has any thoughts on how this assembly is built. I did see another approach by Dan Kolbert in a JLC article which seems more obvious in terms of how to build it...
