Exposed Frost Protected Slab
Well be starting construction on our new home in Freeport, ME this Spring, using a Frost Protected Shallow Foundation (with the WarmFörm product) for both the main dwelling and a detached garage/upstairs apartment. The garage slab will be constructed using the skirt insulation specs for an unconditioned space, while the main dwelling will be built on a slab designed for a conditioned space (less foam skirting). The plan is to begin construction on the garage, and move into the upstairs apartment while we finish the main dwelling. There is a possibility that we won’t have the main dwelling dried in before winter arrives, leaving a FPSF designed for a conditioned space exposed to a Maine winter. How risky do you think this would be? I plan on up sizing the skirt around the main dwelling as a precaution (say 2 feet of 2” EPS all around), any other ideas to protect the slab should this be a situation we’re confronted with? I’m assuming snow cover would help a bit. The slab will be on a well drained, frost resistant gravel base. Floor plan attached. Thank you
There is certainly some risk there. how much risk is difficult to predict. The risk of frost heave is very site dependent. Some factors that would reduce/increase the risk:
-coastal sites are often much warmer than the climate zone would indicate
-Well-drained soils are less prone to frost heave than heavy soils.
-Good site drainage will reduce risk. Wet sites have higher risk. A dry site with ledge close to the surface would have very low risk.
-If you can provide good site and subsoil drainage, your risk will be significantly reduced. A thick stone base with drain pipes that daylight would be very good protection.
Thanks, Peter
Hi Christian -
seems like the biggest threat would be UV degradation; can you protect for that?
Peter
If you can get some BLACK poly sheeting you can use that for UV protection. It will also help to keep things a little warm (tenting) if it gets exposure to the sun. Cheap and easy, and probably about the best you can do.
Bill
