Framing a Floor with Old Brick Footing
大家好!现在一直在这个网站上潜伏,但最后已经被宣布寻求有关特定问题的帮助。希望我包括一切来帮助你帮助我!提前致谢!
我有一个独立的两个故事的车厢,我正在转变为宾馆。为了让生活空间超过7英尺(并且在没有切割所有东西的情况下允许管道),我需要直接在内部板块上框架(+或 - 几英寸)。
我遇到的混乱,是沿着内墙的旧砖头。
These are the facts I’m working with:
它建于1920年代。墙壁是双重WY砖(手工制作,比当代砖比这么宽),坐在砖头上。最初它坐在泥浆上(我思考)混合,但我挖了出来,做了一些质量倒入的是外部露台和天气密封。只有一堵墙有这种内部基础情况,其他墙是直砖墙到板块。
The first picture shows the outside footing, the second and third show the interior. One picture demonstrates the varying heights of brick. I’ve outlined the brick in red to help show the layout, sorry if that hurts more than helps. The blue line is cement I poured.
Climate zone is 7b, if that helps any.
The second and third photo show the interior side of one wall. There are two rows of brick sticking out as footing onto the slab. It’s not fully sealed (know what to do there, just mentioning for variables) as there are missing bricks and huge gaps/cracks in the mortar. If I had to guess, I’d say someone in the last ‘X’ years tried their own way to fix a leak. Everything else looks to have been done with care, but this footing is nutty.
所以问题是:我如何为我的地板框架设置标题托梁?
我将标题直接放在砖头本身上,让砖块充当板块吗?似乎是错误的,另外,砖基在很大程度上不均匀。虽然我想我可以剪掉它们,或者用混合做一些水平。
Do I set up a plate along the brick footing (which would place it 4+inches away from the wall) and have the joists treat the footing as the joist header? I could use joist hangers, I suppose?
既然我到处都是底蕴,我可以剪切砖头与砖墙齐平吗?似乎我冒着墙的诚信,但我没有真正的想法(显然)。
最后,我想我可以围绕着脚踏实地,并倾倒水泥,以创造一个稳定的嘴唇来修复我的托梁。看起来很简单,但我以前从未见过那样的东西,所以我认为有一个有充分的理由为什么!
再次,对任何提示或想法感谢所有人!
**编辑:地板托梁将垂直砖墙与突出的砖头脚踏实地
***More edits: replace all my mentions of ‘header’ with ‘rim joist’.
GBA详细资料库
我认为你架,但我们需要更多details. The floor can rest on the slab. I'm thinking joists resting on the slab, shimmed every 16-24" inches if needed. Those joists have only a 16" span so you can cut them to almost nothing to get around obstructions or plumbing. If you have interior walls they are only holding themselves up so they can be notched severely as well.
你想要多厚的地板?地板是否会被绝缘?墙壁是否会结束?
谢谢你的回应!
So when you suggest to frame around it, what do you mean exactly? Like, have the header on the slab next to the protruding brick, or kinda atop it and cut the joists to lay across?
我应该提到的是,地板托梁将垂直于墙体跑到墙上。
You don't need headers because the joists are resting on the floor. You just need something to keep them from falling over -- blocking in the middle and rim joists on the end. At the end where the brick protrudes notch the joists and use a smaller rim joist.
是的,道歉。我绝对令人困惑地困惑标题的衣架。
好的,我想我得到它。当我将一个窗台板(或者我可以将木材铺设)来对待突出的砖,如果这更好),也可以使用2x4或2x6作为边缘托梁。应该建立与砖块的连接,你觉得什么,还是应该没事的?
谢谢你花时间回答。老实说,你提到我的托梁在地板上休息是最大的帮助!它触发我仔细检查我的本地代码。我肯定是从之前迭代到这个当前一个计划的代码要求。意识到对我来说清楚了很多额外的工作,所以谢谢你!
To answer your earlier questions:
我无法在地板上比2x8更宽,我的生活空间(7英尺到天花板间隙的危险额。这是超级紧张的,但我可以做到它的工作。我可能会养浴室区域,并在一楼的其他地板上使用睡眠者托梁,所以它不是那么狭窄的感觉。
这堵墙将被留下为暴露的砖(Shoutout to Insofst,允许发生这种情况!非常重要,强烈建议您是否有Rescheck问题则检查它们)。另外两个墙壁,一个与完成相反。
I'll likely insulate under and over the bathroom, but not worried about anywhere else in the floor area.
