固定在拉链上
DREWFRIDLEY7|Posted in一般的问题on
我打算使用ZIP R-sheage。我已经读过Fasenters不应压缩绝缘材料。在护套上如何安装任何形式的壁板?如果我不能将孔固定在连续的热中间和/或用紧固件压缩外部绝缘的情况下,我不明白如果不能将其固定在拉链系统上,我不明白它将如何固定它?
GBA细节库
由气候和房屋部分组织的一千个建筑细节的集合
搜索和下载施工详细信息
Do you really want to delete the list,?
这不会删除您保存的文章,只有列表。
This feature has been temporarily disabled during the beta site preview.
Drew,
https://www.huberwood.com/uploads/documents/technical/literature/zs_r-sheathing_installation_manual-r3-12v21.pdf
这只是我的看法 -
不要以为厚的拉链套在任何地方都有很大的位置。它仅提供剪切能力的一小部分,作为标称的7/16额定结构面板,即使您可以正确钉住它,也就是这样。它并没有真正提供任何基于任何东西的钉子,因为它是如此薄。它太厚了,无法准确地钉在螺柱上,即使可以的话,您每2-4英寸都可以钉在钉子上。这些螺柱的指甲比我当地的家得宝。
对于较薄的面板,R3,一切都要简单得多。但是更厚,我会考虑采取相反的路线,并在护套顶部使用外部绝缘 +毛茸茸的条。它只是提供了一个更容易的实用程序,可以使壁板附着并保持细节构建友好。
您是说您建议您推荐1英寸的拉链r-sheage吗?但是没有什么厚?我不熟悉拉链上的毛茸茸条。您有建议的视频吗?感谢您的智慧!
Drew,
What I’m getting at, is that ideally you want your sheathing to be in contact with your studs, and the further you move it outwards, via the insulation thickness, the worse it gets at everything it is supposed to do. That is why I said some of the thinner panels would works fine, and behave nearly like normal sheathing. After all, one inch total thickness isn’t really all that different from 1” board sheathing that used to be common place. You can attach siding through it to the studs fairly easily, and for the most part you don’t know the difference between the combined insulation and sheathing (zip R), and normal plywood or osb.
我会这样说:我会很舒服使用ZIP R3面板,就好像我在使用商品OSB一样。如果符合组合的腔体绝缘材料满足绝缘需求,那么一切都很好。
然而,如果总r淡水河谷低于我的需要ments, then I would scrap the zip r sheathing all together, and use regular zip, without the attached insulation, or plywood and osb with a weather resistant barrier like tyvek, typar, or barricade, and place insulation outside of that. That insulation can be XPS, Polyiso, or mineral wool, in the right thicknesses. 1x or sometimes 2x 4 boards, or furring strips as you’ll see them often on this site, attach to the wall through the insulation, through the sheathing, and into the stud to hold everything in place. This provides a mailing surface for the exterior cladding, while simultaneously providing an air gap, or capillary break, between the insulation and backside of the cladding.
如果您用Google Google“完美的墙”和Joe Lstuberick博士,您将开始获得显示安装方法的链接。YouTube也有很多资源也证明了这一点,Matt Risinger的频道通常是大多数人遇到的第一个。一旦您在正确的术语上校准了Google FU,就有许多其他。
这是一个可以让您前进的链接:
https://www.buildingscience.com/documents/insights/bsi-001-the-perfect-wall
+1凯尔说得很好。
沃尔塔
