I have a green home that has foam insulation,except the garage attic and exterior walls are not insulated.If I blow in cellulose will it void the green label that the home is described as
NCTexan| Posted inGeneral Questionson
Cellulose garage in a green rated home?
By any metric I can think of, cellulose is greener than foam. I'm not sure whether the label your have is from any specific program, but your proposed work will only make it greener.
Do you know the name of the program?
