Is it OK to use Tapcon anchors to fasten the wood plate to the concrete block?
I`m removing a non-functional 6FT. aluminum sliding door and replacing it with a 3ft. steel entry door. When we removed the old 6ft. door we found that the cement blocks (existing) were all loose,cracked & or broke. and the wood was also rotting. My plan is to make a 2″x 8′ step wall out of treated lumber and fasten it to the existing solid blocks with the Tapcons. I`m not sure if it is ok to do this that way. Or if I have to put bolts or rods in with cement the core of the block.
Herb,
We need more information.
1. How many concrete blocks are "loose, cracked, or broken"?
2. Do you plan to remove the loose, cracked, or broken blocks?
3. What is a "2"x 8' step wall"?
