GBA Logo horizontal Facebook LinkedIn Email Pinterest 推特 Instagram YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon Plus Icon Minus Icon Picture icon Hamburger Icon Close Icon Sorted
社区and Q&A
Mini split roof mounted condenser noise issues
JCS_Ltd|发布GBA Pro Help上
Hello,
I am working on a project where the homeowner has just finished having a Fujitsu mini split system installed with the condenser mounted on top of a flat roof. The property is located in the Bay Area, climate zone 3C. He is now asking me for a solution to control the noise that can be heard inside the house. Currently the condenser sits on top of a simple 2×4 redwood frame (the 2x4s are on their side for a height of 3 ½”) that the HVAC installer built to lift it off of the roofing surface.
The roofing assembly is composed of rolled mineral surface, underlayment, 1″ of large fiber insulation (I don’t know what type it is – it’s black and a rigid sheet, looks a bit like dried ramen), and 2×6 T&G Douglass Fir decking which is finished and exposed to create the interior ceiling.
My question is what methods would be best to try and isolate the sound and vibration transmission on the outside of the building that can hold up to the elements and UV exposure? All of my preliminary research points to interior solutions which is not possible in this case due to the finished ceiling being the underside of the roof deck.
预先感谢您的建议
James
  1. Jon_R||#1
    Try a vibration pad. Preferably thick, heavy and covering the entire area under the compressor.
  2. Expert Member
    彼得·恩格尔||#2
    If you know the weight of the unit and the frequencies you need to control, you can get over the counter vibration isolators that will help a lot. Google the terms, and find something that will work. Basically, you mount the isolator to the 2x4 dunnage, and then mount the condenser unit to the isolators. Many even have threaded studs that can be fastened directly to the equipment.
  3. Expert Member
    AKOS TOTH||#3
    James,
    First step is try to get the unit away from bedrooms and close to the supporting wall.
    I use an app for my phone to get a reading on the frequency you need to isolate for. For AC this would be between 6o to 100hz. This is important as isolators are only effective down a to a minimum frequency. Good start for parts:
    https://www.lord.com/products-and-solutions/vibration-and-motion-control/industrial/isolators
    为了获得更好的性能,最好将支撑结构安装在重型摊铺机等重型上。确保您的屋顶可以承受额外的重量。
    Dealing with the noise from the inside is next to impossible at is carried by the structure. You want to prevent the noise getting into the structure in the first place.
  4. 内磷脂||#4
    These harmonics are normal, and may be exaggerated by the way the building materials were constructed or the materials that were selected.
    For mid roof installs we use what is coined as a spider stand. Big stand with four legs with flat metal under the legs to prevent cutting the roof (and for mounting to the roof surface).
    Most of these stands come with rubber isolation bushings for when the unit is screwed to the stand. This may or may not help however installing the unit on a solid surface as it has been insatlled, one that doesnt have mass (like concrete) causes the issue your witnessing.
    请记住,大多数支架防止由于底座上的腿部范围很大,因此该设备无法在大风条件下翻转。不固定时,拆分单位往往会翻身。
    Moe H
Recent Questions and Replies
