GBA Logo horizontal Facebook LinkedIn Email Pinterest 推特 Instagram YouTube Icon Navigation Search Icon Main Search Icon Video Play Icon Plus Icon Minus Icon Picture icon Hamburger Icon Close Icon Sorted
社区and Q&A
Minisplit in California
Stephen Houlihan|发布Mechanicals上
我计划在加利福尼亚沿海地区拥有一个640 FT2的奶奶单位。我浏览了博客,但没有找到所需的答案。该建筑物将是独立的和高度隔热的。我想使用一个迷你拆分,因为即使距海洋仅1英里(第3区),我也需要一些冷却能力。乘员有MS,并且非常容易过热。任何人都可以推荐一个由CEC批准在加利福尼亚使用的迷你切片。我花了一些时间查看他们的数据库,但我发现在那里找不到任何东西。
Steve
  1. GBA Editor
    Martin Holladay||#1
    Stephen,
    您确定加热和冷却设备是否需要得到加利福尼亚能源委员会的批准,然后才能合法安装?我觉得很难相信。
    我从来没有听说过加利福尼亚州的任何法律问题,与安装无管道板单元的安装有关。
  2. Stephen Houlihan||#2
    像大多数其他能源代码一样,《加州能源法典》(通常称为标题24)将建筑物与相同大小的“型号”进行比较,您需要证明它至少与模型房屋一样高。除非没有其他选择,否则几乎完全禁止电阻加热。允许进行热泵,但在介绍中说:“如果您打算使用它,则有一些很大的权衡,您必须使用CEC“批准”的单位。
    Steve
  3. GBA Editor
    Martin Holladay||#3
    Stephen,
    That's news to me. Do any other GBA readers have more information in this issue? Is there a published list of CEC-approved ductless miniplits?
  4. Expert Member
    Dana Dorsett||#4
    IIRC在CA标题24 2008年(目前有效)的IIRC必须具有最低HSPF为7.7的最低HSPF,以在CA下在Title 24下进行供暖,而在大多数迷你片中,跨越13或更高的先知,障碍物很容易清除。除此之外,SFAIK没有安装它们的特殊认证和标签要求 - 没有“ CEC批准的设备列表”,只是最低效率规格。
    Somewhat dicier, mechanical systems may not be oversized by more than 15% for the load(s) per a Manual-J calculation, which may be impossible to meet for small-house small-load situations, even with a 3/4ton mini-split. There bits in the code for HVAC systems regarding ducts that don't apply with mini-split, nor does the code sufficiently address the fact that most high efficiency mini-splits are fully modulating systems with more than 3:1 turn down, and will actually run at somewhat higher average efficiency when oversized for the peak loads by about 25%.
    Then there's the refrigerant charge inspection verication rules that can't always be strictly complied with. Mini-split issues are currently under active investigation for purposes of updating the CEC for 2013 (which becomes effective January 1 2014) since much of the verbiage in current code presumes ducted split systems, with refrigerant charge verification methods commonly used in split systems that simply can't be followed in all ductless cases due to real structural differences eg:
    http://www.energy.ca.gov/title24/2013standards/prerulemaking/documents/current/Reports/Residential/HVAC/20110927Temple_MiniSplit_Investigation_acptchng.pdf
    And see section on page 51 (.pdf pagination) here:
    http://www.energy.ca.gov/title24/2013standards/rulemaking/documents/final_rulemaking_documents/23_march_13_hearing_13_hearing_residential.pdf
    But SFAIK that has never stopped mini-splits from being installed in CA, as long as they meet the 7.7HSPF/SEER13 minimums, and are often a listed feature in deep energy retrofits presented as exemplary projects, eg:
    https://www.smud.org/en/residential/save-energy/success-stories/documents/Case-Study-Jean-Ave.pdf
    Title 24 2008 in fact DID make accommodating specifications for PTHP/PTAC units, but for somehow mini-splits escaped the regulatory radar when that was being drafted. See:
    http://www.energy.ca.gov/2008publications/CEC-400-2008-016/rev1_chapters/RCM_Chapter_4_HVAC.pdf
    Bottom line, aside from a potential oversizing specification issue for such a tiny/low-load space, almost ALL mini-splits would exceed the basic raw efficiency requirements under the CEC with margin. There is no special certification or labeling step required for approval- just published & verifiable HSPF and SEER numbers that meet the spec. With literally hundreds of mini-split installers in the state, you'd probably have to go way out of your way to find a mini-split for sale in CA that wouldn't pass muster with the CEC.
  5. GBA Editor
    Martin Holladay||#5
    达娜,
    Thanks very much for the helpful information.
Recent Questions and Replies
