泥房的地板内辐射热
daniel_grant|发布能源效率和耐用性上
我正在查看我在加拿大安大略省(6区)的房屋中增加了一个小(8'x10')。我已经用霜冻墙安装在坡度上的平板上,增加将在加热区域内,向我的地下室打开。
My house is 70 years old and heated by hot water radiators and I don’t want to get into adding a loop, and the mudroom would be basement temperature, not living space temperature, I think I’ve settled on electric radiant heat in the floor. Other than being open to the basement, this would be the only heating of this mudroom. I imagine it being set to a low constant temperature to keep floors dry, snow melted, etc. There’s an interior door that will remain which separates it from the rest of the house.
I’ve read that slabs tend to act as a heat sink, but I see this almost as a feature, as it seems this would regulate the temperature as kids are running in/out and bringing snow in. I have 2″ GPS to go under/around the slab to minimize losses to the ground.
只是好奇我是否远离基地,或者有更好的选择选择。
    尼克·基南||#1
    我看不到这里加热地板的任何优势。听起来您真正想要的只是未加热的空间。如果您想要的是偶尔的热量,电动踢脚板可能比地板热量更好,并且成本要多得多,并且更可靠。
    1. daniel_grant||#2
      我不想要一个未加热的空间,我希望不断的低温空间,以确保房间/地板足够温暖以使其干燥。
        尼克·基南||#5
        您可以使用底板电加热器获得。比地板更便宜,更简单,更可靠。
  2. plumb_bob||#3
    在浴室之前,我已经将电辐射热量放入瓷砖地板上,结果非常好。我认为,自每年5个月以来,您将与雪进行打交道,因此加热的入口板将很棒。
    马尔科姆·泰勒(Malcolm Taylor)||#4
    丹尼尔,
    我同意plumb_bob。这些一个房间的辐射地板很有意义。它们避免了较大系统的复杂性,同时准确地提供您最想要的热量。
    我对您的气候不太了解,无法说出2英寸的GPS是否是适量的亚样物绝缘材料。
登录或创建一个帐户以发布答案。
最近的问题和答复
