Rainscreen behind stucco for closed-cell foam insulated wall?
Hello,
I have a question regarding the need for a rainscreen between the lath and building paper on a closed cell insulated wall. What is the best way to do this, and is this necessary if the building is in southern California? I have two inches of closed-cell spray polyurethane foam sprayed against interior of the plywood sheathing.
Thanks!
Andrew,
I strongly advise you do include a gap between the stucco/lath/building paper and your plywood wall sheathing.
This article includes the information you need to know:To Install Stucco Right, Include an Air Gap.
Thanks for your response. Would the gap be between the lath and building paper or between the building paper and sheathing?
Andrew,
The answer can be found in the article I linked to. You'll need at least two layers of WRB material (for example, asphalt felt): One behind the three-dimensional plastic drainage mat, and one in front of the three-dimensional plastic drainage mat.
In the article, I wrote:
“If you’re installing stucco over OSB or plywood, here’s how to create a ventilated rainscreen gap:
Install at least one layer of WRB — housewrap, asphalt felt, or Grade D building paper — over the wall sheathing.
Install a three-dimensional plastic drainage mat (for example, Cedar Breather) over the WRB. It’s also possible to purchase all-in-one products that marry a three-dimensional plastic mat with a WRB backing. Such products include the WaterWay rainscreen drainage mat, the Korax Stucco Rainscreen Panel, the Home Slicker Stone & Stucco rainscreen, the Mortairvent mortar deflection and ventilation system, and Delta-Dry.
Install at least one more layer of asphalt felt or Grade D paper on top of the drainage matrix.
Install galvanized (expanded metal) or fiberglass lath, and proceed with a standard installation of three-coat stucco.”
