Community and Q&A
Replace windows
范Lena| Posted inGeneral Questionson
I live in British Columbia,Canada. Please reply the following questions. Thank you.
U-factor (W/m² – K): Is this number lower better or higher better?
U-factor (Btu/h/ft² – °F): Is this number lower better or higher better?
Glazing Cavity Width (mm): Is this number lower better or higher better?
Emissivity: Is this number lower better or higher better?
Low E Surface: Is surface 3 better or surface 2 better?
Solar Heat Gain (SHGC): Is this number lower better or higher better?
Visual Transmittance: Is this number lower better or higher better?
Air Leakage (m³/h/m): Is this number lower better or higher better?
Air Leakage (l/s/m²): Is this number lower better or higher better?
Spacer: Is stainless steel better than Hybrid (metal/non-metal)?
Thank you very much for your help.
范
  1. GBA Editor
    Martin Holladay||#1
    范,
    Many of your questions are answered in this article:All About Glazing Options
    U-factor (W/m² - K): Is this number lower better or higher better? Lower is better.
    U-factor (Btu/h/ft² - °F): Is this number lower better or higher better? Lower is better.
    Glazing Cavity Width (mm): Is this number lower better or higher better? It depends.
    Emissivity: Is this number lower better or higher better? Lower is usually better.
    Low E Surface: Is surface 3 better or surface 2 better? It depends.
    Solar Heat Gain (SHGC): Is this number lower better or higher better? It depends.
    Visual Transmittance: Is this number lower better or higher better? Higher is better.
    Air Leakage (m³/h/m): Is this number lower better or higher better? Lower is better.
    Air Leakage (l/s/m²): Is this number lower better or higher better? Lower is better.
    Spacer: Is stainless steel better than Hybrid (metal/non-metal)? No.
Community
Recent Questions and Replies
