GBA标志水平 Facebook LinkedIn Email Pinterest Twitter Instagram YouTube Icon 导航搜索图标 米ain Search Icon Video Play Icon Plus Icon 米inus Icon Picture icon 汉堡图标 关闭图标 Sorted
Community and Q&A
板坯级地板选项
Bob Holodinsky|发布了General Questions在
我有一个被退休家所取代的小屋。它在安大略省东部的基岩上,我计划在等级上建造平板,除非有更好的选择。它将是1200平方英尺的1.5脚。我希望用先进的框架风格和鞘,带4英寸的外部泡沫。我的问题是关于混凝土楼层。我意识到我可以抛光它并蚀刻它,但我不确定舒适的舒适性的硬表面和脚下冷凝土的温度。我想知道我是否可以把泡沫板放在它上,然后底层胶合板导致正常的房屋地板覆盖物?任何想法都会受到赞赏......问候,鲍勃
加入建设科学专家的领先社区
  1. GBA Editor
    米artin Holladay||#1
    Bob,
    可以在混凝土板上安装任何类型的地板,包括硬木,软木或地毯。任何能力的地板安装人员都可以帮助您了解详细信息。
    Some types of flooring require the installation of strapping or sleepers, so don't make your ceiling too low.
    Your slab will need two types of insulation: vertical rigid foam at the slab perimeter, and a continuous layer of horizontal rigid foam under the slab. You won't need any more insulation above your slab unless your contractor makes a mistake and forgets to put the insulation under the slab, where it belongs.
    不要忘记在水平刚性泡沫和板的顶部之间安装一层6-mil聚四乙烯(或较厚)。
  2. Kevin Dickson, MSME||#2
    米artin's comments are all good.
    I'd like to add that I've been living on a stained slab for eight years and cannot be more enthusiastic about its durability and beauty. Its hardness doesn't bother us, we put down some gel mats in the kitchen work zone.
    The main reason NOT to cover it with foam and plywood and a flooring system is cost. You would be paying extra to have a floor that needs more maintenance. Our maintenance cost has been zero so far and I estimate another ten years before we'd need to do some.
    混凝土楼层总是首次参观家庭的最爱特色。
    泡沫和胶合板也会热“将”与生活空间分离的平板“。这可能是在季节期间的舒适性和效率劣势> 75°F天与<70f不相结合。
  3. Bob Holodinsky||#3
    Thanks for that insight of living on a concrete floor...I was concerned it would feel cold in the winter but you are saying that it is not an issue?...thanks,Bob
  4. Kevin Dickson, MSME||#4
    凉爽不是我们的问题。如果板坯也在卧室和浴室,那么一些放置良好的区域地毯可以解决任何问题。
    Don't let any heating experts convince you to heat the slab, either. It's a waste of money in a well-insulated home, because the heat comes on so rarely. The slab is nearly always cool.
    另一种节省资金的可能性正在使用单片板。只需遵循霜冻保护的浅基金会的设计要求。
  5. Bob Holodinsky||#5
    Thanks...I will read up on a monolithic slab ...I am not familiar with it ...regards,Bob
  6. Gordon Taylor||#6
    我一直想知道的一件事:你如何保持裂缝的裂缝?也许这只是我,但我似乎看到了很多破裂的板坯。在没有其他地板的家里,这将是一个重大的笨蛋。
  7. GBA Editor
    米artin Holladay||#7
    Gordon,
    问:“你如何从破裂中保持平板?”
    A.不要为混合物添加太多水;一旦混凝土放置一次(使用湿粗麻布,喷洒器或固化化合物),通过防止快速蒸发来鼓励缓慢固化;并建立适当数量的控制关节,以便任何确实发生的裂缝看起来不错而不是随机。
  8. John Brooks||#8
    问:“你如何从破裂中保持平板?”
    A.在德克萨斯州北德克萨斯(高度膨胀的土壤)中,大多数平板都有具体的保证
    .... "The Concrete is Guaranteed to Crack"....
    一些绝缘板洞察力可以在“平板愉快”中找到
    http://www.buildingscience.com/documents/insights/bsi-059-slab-happy/files/BSI-059_Slab_Happy.pdf
  9. Kevin Dickson, MSME||#9
    Fiberglass strands added to the mix will pretty much eliminate those micro-cracks. They don't prevent big cracks, though.
    Post-tensioning is a fairly inexpensive way to eliminate large cracks, even in North Texas.
    The best looking control joints are made by cutting the concrete a few days after pouring. Tooled joints aren't as clean-looking.
  10. Gordon Taylor||#10
    Thanks for the interesting replies. To Kevin Dickson: Post-tensioning is something I first heard of as an English teacher in a Turkish technical university. I know how it works for beams, but how on earth does it work for a slab?
  11. Gordon Taylor||#11
    没有双关。请。
  12. James Morgan||#13
    有那些喜欢混凝土地板的人和那些无法遵守他们的人。他们肯定会在脚下很难,因为凯文指出,他们将永远感到酷。而且他还评论热质量将有助于稳定某些气候条件下的室内温度。
    好消息是,如果你决定尝试完成的混凝土,以后决定你不满意你可以随时添加更温暖,如果你选择的话,更宽容的饰面例如,硬木直接放在混凝土上。但是如果你采取这种方法,请务必通过设置台面升高,使洗碗机仍然适合它后,在它下面添加额外的材料 - 例如3/4“。这可以暂时狂热以便整齐。无论你是什么尽管在板块低于它的板块下方隔离。即使在添加光覆盖后,板坯中的热质量也仍然具有值。
    By the way, floating floor materials generally have extremely tough factory-applied UV-cured silicon dioxide finishes which are at least as durable as an etched concrete finish.
  13. Dan Kolbert||#14
    Polishing a slab will be almost as much as laying a floor. But you don't have to polish; we built a house several years ago, added dye in the truck (I think it was well under $1000 for the dye), clients decided not to polish and have been quite happy with the results since then. I think we put a sealer over it but can't remember.
    And as others have said, there are plenty of floors that can go right on top of the concrete (once it is fully cured) - glue-down wood, floating wood, cork, marmoleum, etc etc.
  14. Bob Holodinsky||#15
    我很满意对我的所有信息都有关于平板和地板的所有信息......感谢所有回答的人......这是一个伟大的论坛,我每天学习一些东西......问候鲍勃
Community
