地下室两层维多利亚时代:绝缘plan
Sorry guys (Matt F & Dana Dorsett) — I have been away for a while sourcing materials and making calculations. Hopefully I have done well to your liking…
BASEMENT WALL INSULATION PLAN:
(a top-down sandwich)
1) Thick polyethylene vapor barrier
2) 2-layer soft-fired brick wall
3) 6″ EPS insulation
4) 2×2 framing
5) cement board
6) thinbrick, stone, or tile
BASEMENT FLOOR INSULATION PLAN:
1) Tile
2) Ditra decoupling floor membranehttps://www.schluter.com/schluter-us/en_US/Membranes/Uncoupling-(DITRA)/Schluter%C2%AE-DITRA-&-DITRA-XL/p/DITRA
2) 3″ reinforced concrete slab heated with PEX
3) EPS Amvic pex panelhttps://www.amvicsystem.com/products/ampex/
4) Thick Polyethylene vapor barrier
5) 3″Type-II or Type-IX EPS
6) 6″ washed gravel
ROOF INSULATION PLAN:
//m.etiketa4.com/question/two-story-victorian-roof-insulation-plan
EXTERIOR WALL INSULATION PLAN:
//m.etiketa4.com/question/two-story-victorian-exterior-wall-insulation-plan
BASEMENT INSULATION PLAN:
//m.etiketa4.com/question/two-story-victorian-basement-insulation-plan
Put the poly vapor barrier under the Amvic, above the other foam. If it's on the bottom of the stack in can harbor large quantities of water in pockets. When it's between two flat layers there no pockets can develop.
Use Type-II or Type-IX EPS for the foam under the vapor barrier.
Under the bottom foam it needs 4-6" of washed gravel as a capillary break and drain layer.
Changes made.
Thanks Dana!
