Image Credit: ZeroEnergy Design
A four-bedroom, two-bathroom house its designers named “The Little Green Rhody” has won top honors in a design competition that promotes affordability, reduced fossil fuel use, and a lower carbon footprint.
TheCarbon Challenge Providence Design Competition, sponsored by LP Building Products and Boise Cascade, was based in Providence, Rhode Island, but was open to anyone in the U.S. A total of 144 designers submitted entries to the competition and a simultaneous contest in Baltimore, Maryland. Judges looked at each entry’s carbon footprint, its use of wood, its cost effectiveness, and its appearance, organizers said.
The Providence entries were designed as a Habitat for Humanity project to be built on a vacant lot at 24 Hannah Street. The winning entry is the work ofZeroEnergy Designin Boston.
The 2,000-sq.-ft. net-zero-energy house has an uncomplicated style and a simple, gabled roof. It was considered a good match with traditional architecture in the neighborhood. Among theconstruction detailsprovided by ZeroEnergy Design:
- The R-27 walls are framed with 2x4s on 16-in. centers. The stud bays are insulated with mineral wool or cotton batt cavity insulation. In additon, the exterior of the walls is insulated with a continuous 3-inch-thick layer of mineral wool insulation, which has a “low global warming potential, is not a petroleum-based product, and does not expand and contract like foam-based insulation products.”
- Basement walls are manufactured by Superior Walls of America placed on a rubble footing rather than a poured concrete footing and insulated with expanded polystyrene (EPS) insulation rather than extruded polystyrene (XPS) because of its lower global-warming potential.
- The roof is framed with raised-heel trusses, 24 in. on center. The floor of the vented attic is insulated with 14 in. of loose-fill cellulose for an R-value of 52.
- The European windows are triple-glazed. Door lights are also triple-glazed.
- The air barrier for the walls consists of taped Zip System wall sheathing.
- A 7.5-kW solar electric array is specified for the south-facing roof.
- Domestic hot water is provided by a heat-pump water heater.
- Space heating and cooling are provided by an air-source heat pump. Mechanical ventilation is provided by a heat-recovery ventilator.
Adam Prince, one of three owners of ZeroEnergy Design, said the design team estimated the house would cost about $8,000 more than a code-minimum structure of the same size. (That estimate did not include the cost of the roof-mounted PV array.)
Lower annual operating costs, smaller carbon footprint
Designers predict Little Green Rhody would use less than half the energy of an equivalent house built to code minimums, using a total of $1,460 in energy vs. $3,652 for a conventional house. Savings could be found across the board, for heating, cooling, hot water and appliances. Heating costs were significantly less in the Rhody, dropping from about $2,000 in the comparison house to less than $500.
The design also predicts a reduction of 25 cu. yds. of concrete in the foundation by using the manufacturedSuperior Wall systemand eliminating a conventional concrete footing. The manufacture of concrete represents a major global warming contribution.
One of the surprising results came in the area of windows. Designers found less global-warming potential in shipping windows in from Europe than it did in buying them from U.S. or Canadian suppliers.
“Shipping the windows across the sea can actually have a smaller carbon footprint than trucking them across the country or [from] Canada, where some of the best-performing windows in North America are currently made,” the project description says. “Shipping from manufacturing facilities to ports in Europe is often a short distance by truck or rail.”
Using a carbon calculator from Log-Net, designers predicted that buying German windows over Ontario windows would lower the building’s carbon impact by 5%.
Other winners
A total of $10,000 in prizes was awarded. Other winners included:
- Kyle Bamrick & Christopher Armstrong of Providence, second place ($2,500 cash award).
- Joseph P. Campanella — Design Alliance, LLC, of West Hartford, Ct., third place ($1,000).
- 最好使用木制品(500美元):安妮·Lissett & Benjamin Monroe — LEAF Architecture of West Hartford.
- Best Curb Appeal ($500): Erik Rhodin and Taina Rhodin — Line Company Architects of Waltham, Mass.
- Most Cost-Effective ($500): Christen M. Robbins —- Vision 3 Architects of Providence.
森林碳的挑战是由Products Laboratory, a research arm of the U.S. Forest Service, and the APA—The Engineered Wood Association, an industry trade group. The initial design contest took place in Florida in 2010 as the two organizations looked for a way to promote the carbon neutrality of wood.
The APA said it was likely Habitat would eventually build the house when the right family and funding became available.
Weekly Newsletter
Get building science and energy efficiency advice, plus special offers, in your inbox.
8 Comments
It's cheaper to spend more
Here's one interesting observation, which of course has been made before. Amortizing that extra $8,000 of building cost over a mortgage @4% costs $48.48/mo (20 years) or as low as $38.19/mo (30 years). The average monthly saving on energy from the numbers cited is $182.67, of which at least $125/mo was the heating saving. The cost of ownership is lower for the more expensive house. In approving mortgage loan applications, a bank really ought to quit using PIT (principal, interest, taxes) as some percent of income (30%?) and start using PITE, the "E" meaning energy. In the above case, it would lower the bank's risk to approve the more expensive but superinsulated house vs code minimum.
What HE said...
+1 on Dicks PIT-E vs. PIT assessment of the financials! Even if there is significant energy price deflation over the coming decades (not likely) PIT-E is simply a better metric for the viability of the loan on day-1, and hedges against future energy price inflation (more likely, but not guaranteed.)
Response to Dick Russell and Dana Dorsett
Dick and Dana,
I agree that a more expensive house can save money and (if the incremental costs are financed) result in positive cash flow from from Day One.
That said, I'm a little suspicious of the $8,000 figure for the estimated incremental cost. First of all, this house hasn't even been built yet. Second, it's going to be hard to find a contractor to install a 7.5-kW PV system for less than $30,000.
Martin, I too am skeptical as
Martin, I too am skeptical as to whether the 8K included anything but the house framing and insulation. Assuming that, the numbers for just heating are quite realistic, for an immediate savings of at least $87/mo over 30 years or 77 over 20. I wouldn't expect the numbers for adding on the PV upgrade to have immediate payout. Perhaps Mr. Gibson can comment, or someone from Zero Energy Design, if they are tuned in.
The estimate was the increment for the base design
The base design is simple which helps to make it more affordable to build - it's four corners with a gable roof, a reasonable starting point. Affordability was one factor of several in the competition, but not the sole determinant.
As we mentioned to Scott, without factoring in the possibility of in-kind or discounted materials (this is a Habitat house), we estimated the premium for the materials (insulation, HRV, better windows, better hot water heater, etc) in the base design without the PV. Sorry if that wasn't clear. This is the estimated cost increment compared to code minimum. We haven't received feedback from Habitat as to how the cost of this base design compares to their existing designs.
Response to Adam Prince
Adam,
Thanks for the further information. I have edited the article to reflect the fact that the estimated incremental cost of $8,000 does not include the cost of the PV array.
Net Zero HOT !
Thank you for the communication.
Is there any currently useful, Air Solar in 3way air valv-ing for as a rated accepted system for space conditioning as well as water heating; and tangentially possibly just air purification with fancy filtering; and lastly possibly the HERV or ERV as an adder?
Response to Jon Pierce
Jon,
You asked three questions.
Q. "Is there any currently useful, Air Solar in 3way air valv-ing for as a rated accepted system for space conditioning as well as water heating?"
A. Solar air systems have been used for space heating for decades. The cost of the equipment is so high, and the value of the collected energy is so low, that almost no one installs them anymore. I'm sure what you mean when you propose using a solar air system for water heating. If you mean something like putting a black water tank in a greenhouse, that has been tried, and some people still do it. Be my guest.
Q. "[It is] tangentially possibly just air purification with fancy filtering?"
A. Many manufacturers make air filters.
Q. "Possibly the HERV or ERV as an adder?"
A. Many manufacturers make energy-recovery ventilators (ERVs).
Sign up Log in
