GBA徽标horizontal Facebook LinkedIn 电子邮件 Pinterest Twitter Instagram YouTube图标 Navigation Search Icon 主搜索图标 视频播放图标 音频播放图标 耳机图标 加上图标 减号图标 Check Icon Print Icon 图标图标 Single Arrow Icon 双箭头图标 汉堡图标 电视图标 关闭图标 分类 汉堡/搜索图标
木舌和槽板中可接受的水分含量水平?
史蒂夫Lenertz|Posted in一般的问题on
To all,
这个网站和web搜索。令人惊讶的是,我could find very little on what is an acceptable level of moisture in wood V groove T&G 1×6″ paneling. FYI the wood species is Red Pine (Norway Pine)
The ceiling areas the wood will be placed has a 1 1/2″ space behind it and the air barrier.
我发现了窑干的1/3的木材,并在我需要的时间内发现了一些木头。但是,木材被空气干燥,目前显示出10-12%的水分含量。我认为窑干大约是一半。
The wood I found is of high quality. I have purchased wood from this supplier for a log home in the past, and have been very pleased. The current project unlike the log home is very airtight and energy efficient.
想法?
史蒂夫
  1. GBA编辑
    Martin Holladay||#1
    史蒂夫,
    The table below comes from this resource:国家木地板协会安装指南。
    许多资料来源告诉安装人员的目标水分含量为7%至8%,但答案在一定程度上取决于地理位置和气候。在冬季,室内RH水平在非常寒冷的气候下比更轻微的气候低。
    I've never seen softwood tongue-and-groove boards buckle after installation; in general, installing dry is better than installing damp. (When installed during hot, humid weather, softwood boards are likely to shrink the following winter.)
    传统的建议是在室内仔细地堆放木板,每层木板之间的贴纸和板之间的空气循环之间的间隙,并将中央暖气放在70华氏度。做好。
    Using a moisture meter can be tricky. You might want to read this article:水分测试木地板时避免这些错误。
    迈克尔·梅纳斯||#2
    我已经安装了比原本应该干燥的松木地板,并在扩展时压碎了边缘。当相对湿度上升时,我还安装了一个太干和屈曲的樱桃地板。许多T+G装置在收缩时显示出空白。因此,我认为有理由关注。正如马丁所说,这在某种程度上取决于您的情况。V型匹配有助于隐藏一些动作。
    在我所在的缅因州,我们可能是该国湿度最高的波动,因此冬季的平衡木材水分含量(MC)约为6%,夏季为14%。在海岸上有点潮湿。理想的MC取决于一年中的时间,安装位置,木材的种类,木材成员的大小,木材的膨胀系数(随着水分的变化而移动多少,取决于物种和谷物方向),建筑物的哪个阶段在(新的且仍在释放施工水分,还是旧的?)等。
    If you're interested in "going deep," this book covers the subject:https://www.amazon.com/understanding-wood-craftsmans-guide-technology/dp/1561583588。
    马尔科姆·泰勒(Malcolm Taylor)||#3
    史蒂夫,
    跟随ing the table in Martin's response is the way to go. Acclimatizing wood to the conditions present during installation is a hit or miss approach.
  4. 罗伯·迈尔斯||#4
    以上所有内容都是很好的建议,但是空气干木的运动量可能是天花板的。假设最坏的情况(切向收缩,扁平木材,不适应),1x6红松板的尺寸变化从12%到6%的水分约为3/32英寸(根据Martin提供的图表,平衡MC可能高于6%)。在我的房子里,我在天花板上使用了适应的空气干燥的白松,没有问题(实际上,我认为窑干可能会有更多问题)。
    我总是预先限制木板(如果收缩,舌头上新裸露的表面显示较少),并且在天花板的边缘留下一个小间隙,以允许任何运动。
  5. 史蒂夫Lenertz||#5
    Thanks for the responses so far. Just to clarify the 1x6 T&G will not be for flooring, but for walls and ceiling.
    史蒂夫
登录或创建一个帐户以发布答案。
Community
最近的问题和答复
