Aeroseal管道密封胶
洛瑞威尔逊|发布了绿色产品和材料在
你好。我的供暖和空调技术建议aeroseal修理泄漏管道工作在我们的墙壁。我们将取代我们的阁楼管工作,但希望这个产品,所以我们不必撕出墙。有没有人有这个产品的经验吗?它说,是被低VOC和非易失性乙酸乙烯酯。我认识到,密封小孔是使用更少的电力,并产生粉尘少这又产生更好的空气质量,但如果aeroseal关闭气体,并最终降解加班那么我只是在不同类型的污染物的呼吸好?这似乎好得是真实的,除了成本。
    洛瑞,
    Aeroseal是住宅的工作很少使用,因为其成本较高。主要缺点是,它是不符合成本效益。
    下面是一个相关文章的链接(下文评论):
    请问Aeroseal工作?
  2. 布拉德李||#2
    Aeroseal has actually been used to seal ductwork in thousands of homes across the U.S. While it isn't cheap, the DOE says its effectiveness provides one of the largest energy saving ROI's available -- about 2-8 years (compared to Window upgrades at 70 years / wall insulation at 90 years). You'll find government research that finds Aeroseal to be up to 60% more effective at sealing leaks than traditional duct sealing - that's because it can get to all the leaks - even those in ductwork that are hidden behind walls, under insulation, in tight crawl spaces etc. As far as it being safe...if you don't trust the MSDS documents that say it is perfectly safe, consider that it has been used at the Mayo Clinic, Nemours Childrens Hospital, NYU Medical Center, and other locations where you know they did their research before OKing its use. A quick Google search will find lots of credible articles - from Consumer Reports, to EPA studies, to This Old House magazine that look at this innovation as a real breakthrough for homeowners.http://1.usa.gov/LvCQOH。
    马丁·霍洛拉||#3
    注到GBA读者:布拉德·李,布拉德又称为布伦纳是布伦纳协会,有合同市场Aeroseal该机构的负责人。
    请注意,以营销谁试图GBA上发布广告:使用化名,并不免除您的要求为您遵守与我们网站上限制垃圾帖子GBA政策。
    我们有时会允许营销商发表相关评论 - 但被警告:这是你必须确定自己作为雇员或代表一个营销公司的您发布此类型的宣传材料之前。
