鼓风机门减少250 cfm,减轻ra速度。为什么????
欣赏这里帮助我的家解决“奥秘”的所有明亮思想。我还有另一个希望能提出一些想法的问题。在有或没有我的ra扇/系统运行的情况下,都进行了鼓风机门诊断。ra扇在家庭外部,管道在条件和密封的爬网中的120万蒸气屏障下运行)。ra扇工作时,我们以前在爬行空间中经历了明显的湿度。现在(感谢这里的每个人的帮助),我们已经纠正了这个问题,现在爬网空间保持不变。
My question is: Why are the blower door results 250 cfm lower when the radon mitigation system is on( sub slab/Fan tech HP 220) on, than when it’s off? Blower door test was 3428 cfm with Radon on, 3678 with Radon mitigation off.
Thanks!
GBA细节库
由气候和房屋部分组织的一千个建筑细节的集合
搜索和下载施工详细信息
这可能意味着您在蒸气屏障和/或平板和/或基础墙壁上有泄漏,并且ra扇正在使地下室压抑,从而抵消了一些堆栈效应的贡献。
鼓风机的门数可能是随着房屋的解压缩,不是吗?如果您用加压的房屋进行测量,则打开ra扇可能会使鼓风机的CFM数量增加类似的数量。
3400 CFM/50仍然相当重大泄漏,可能值得追逐并修复其中一些泄漏。
谢谢达娜,
对不起,认为我向后。第一个blower door test was done with the radon on and measured 3428 cfm. Right afterwards, the radon fan was turned off and the Blower measurement was 3178 cfm. The vapor barrier was just re-sealed with Mastic, and the foundation walls were spray foamed ( closed cell). Could the radon fan be pulling air from somewhere else...attic maybe??? House is very humid when it's humid out too. Appreciate your help-driving me nuts trying to figure this out!!
Thanks
I forgot to mention the crawl space is no longer humid ( stays 39-40 % RH) since it was re-sealed ( spray foam foundation walls, mastic seal to vapor seams), and does not fluctuate like the house. That's why I was wondering if the radon could be pulling air from the attic and into the house somehow-especially when it's warmer outside?? Right now it's temperate outside ( 55-65 degrees) and HVAC is off-which makes it more humid. Have been having to turn on the AC at times just to keep indoor RH below 54% -even though the indoor temps are 72.
Have you inspected the fan and pipe in the attic to verify that everything is connected properly?
嗨,史蒂夫,
我应该提到风扇和管道在房屋的外部。它在拱腹通风口/屋顶(一楼)上方几英寸处驱动。
Do you have a sump pump in the crawlspace or cinder block foundation walls?
Steve,
I have cinder block foundation walls which were spray foamed when the crawl space was encapsulated/conditioned. I don't have a sump pump, and there aren't any water leaks/infiltraions in the crawl ( I regularly check following a heavy rain). The crawl space seems to stay dry with low humidity 39% RH/72 degrees, and doesn't vary too much with the outdoor weather. The interior is the opposite-humidity indoors directly corresponds to exterior humidity/dew points.
Thanks
我还有一个专用的管道除湿机在爬行空间中运行。几周前,我的接缝处的爬网空间蒸气屏障在接缝上重新密封,因为爬网空间湿度也很难保持低于50%的水平,即使除湿剂24-7运行。由于爬网被重新密封,湿度保持恒定为40%,除湿机很少运行。不幸的是,现在房子比以前更潮湿了。我认为ra扇在鼓风机门测试期间由于250 cfm的差异而对压力产生影响????希望解决。
Thanks
I was curious about the foundation since concrete blocks are porous and might be providing a path for air movement.
我可以问一些其他问题,但认为您应该聘请Resnet顾问来看看您的爬网,阁楼和HVAC系统。
