condensation risk?
My ~110 year old home has hot water radiator heat. In the basement, the 2″ radiator pipes are covered in asbestos insulation that’s approximately 3/4″ thick. Most is in good condition (1 picture of that), but there are a few places where it’s been damaged (1 picture of that). I was considering wrapping them in plastic to reduce the odds of airborne asbestos particles, however I was slightly worried that this might trap moisture. Should this be a concern? Basement temperatures range from low 50s in the MN winter to mid 70s in the summer. Finally, if anyone has advice for wrapping these pipes, I’d be very interested.
There are encapsulants made for this kind of thing. I'd check with an asbestos abatement company for specifics. My understanding is that there are paint-on or spray-on coatings that can act as encapsulants.
I don't think mositure would be an issue. Common commerical fiberglass pipe insulation often has a rigid plastic outer covering, and I've never heard of that being a problem. If the pipe is going to leak, it's going to come out at the seams of the insulation regardless.
Bill
