难以的绝缘改造
黛安施奈德|发布能源效益及耐用性在
我一直在阅读许多关于绝缘改装的非常丰富的博客文章。我们有点艰难的困难。我们的房子是一个半故事,我们之前已经绝缘了屋顶的倾斜部分,膝盖壁的两侧,然后在平坦部分的顶部 - 上方天花板上方。我们有一种材料的集合,因为我们试图在椽子之间喷洒泡沫,在椽子之间,它们在它们被暴露的地方露出并且在它们未暴露的空腔中。这是多年前 - 至少15岁,我不知道它是否被关闭或开放的细胞泡沫 - 我所知道的是它是聚氨酯泡沫。试图在空腔中喷出泡沫的令人震惊的失败,所以我们将其中止了一半。我们最终从房间内部开放了洞穴,并刮掉了所有被放入它们的泡沫。What I now see that we should have done THEN was have foam sprayed in between the now open cavities but we had had it with this guy because we’d tried to get some money back from him before we decided to proceed by doing a tear-out from inside. So, what we ended up doing was putting EPS in the open cavities (foaming them in for a tight fit). We have 2X6 rafters, so about 5 1/2 – 6″ thick EPS, plus 1 inch of Thermax on the interior then drywall over that. However, on one side of the house, the foam that had been sprayed in between the rafters was okay so we just put Thermax and drywall over it and didn’t vent that side of the roof (the south side). On the other half of the house we put the EPS plus Thermax but we used thinner billets of EPS such that we left around a half inch airspace behind/above them to ventilate at least half of our roof. We have soffit vents (unboxed soffits – the vents are perforated strips cut into the blockers between the rafters (I don’t know what you call those) and then we have a ridge vent. Above the ceiling we have a conglomeration of cellulose plus some fiberglass bats laid over top that had previously been in between the rafters.
因此,现在我们需要一个新的屋顶,并意识到我们有另一个机会从上面解决我们的绝缘情况。我们也有一些漏气泄漏,因为当我们从内部进行撕裂和改造时,我们难以做好密封。我希望可以通过在问题领域撕掉屋顶护套,我们可以从上面解决它,但我们希望避免做完全撕裂。你会建议什么?我们在6区。
黛安施奈德
    黛安,
    问:“你会建议什么?”
    答:很难说,因为我不知道你现有的绝缘是良好安装的,还是预算有多大。
    如果你有5.5英寸的eps,那就是R-20 - 并不多。通过在现有的护套顶部添加更加刚性的泡沫绝缘材料,可以提高屋顶绝缘材料。但我不知道你的倾斜屋顶是多少,以及多少覆盖着一种通风的阁楼。
  2. 黛安施奈德||#2
    大约2/3的屋顶是倾斜的,1/3的屋顶覆盖着通风的阁楼。至于预算,我想知道理想的解决方案是什么,并花费在那里,然后从那里缩减,如果我们负担不起。我们也在讨论金属屋面和沥青瓦的优点,如果这有什么不同,或者如果你有关于这方面的建议。
    黛安娜
    马丁·霍洛拉||#3
    黛安,
    在第6区,天花板的最小代码R值是R-49,因此您需要另一个R-29,只需几乎无法满足代码。如果您想达到该号码,您需要在屋顶上安装至少4.5英寸的刚性多异氰泡沫泡沫塑料泡沫。让我们安装6英寸 - 毕竟,你问了“理想的”屋顶。
    金属屋面是比沥青瓦更好的选择。
  4. 黛安施奈德||#4
    如果我们要安装那么多保温,你会觉得使用1或2英寸厚的床单,蹒跚地接缝,或者使用像钉子等东西(假设我们买得起)?空域怎么样?我们需要一个吗?我们在我们的一半屋顶上的护套下的空域怎么样?我们可以接近它,仍然在护套上方用上方隔离吗?
    为什么金属比沥青瓦片更好,直接在该空间呢,以防止“出汗”?这是必要的吗?
    哦,还有一个问题:我们的建造者邻居试图销售我们的P2000绝缘的想法,说它相当于R25或其他东西。对那东西有什么想法吗?
    黛安娜
    马丁·霍洛拉||#5
    黛安,
    很难回答你所有的问题,其中许多都是广泛的和基本的。
    1.如果您在屋顶护套顶部安装6英寸的Polyiso,您可以安全地密封通风滑槽的顶部和底部。
    2.你可以使用2-in。-有交错接缝的厚层聚碳酸酯,或钉基,或sip;你的选择。你可以在当地为这些不同的选择定价。
    3.P2000绝缘的经销商经常被指夸大和欺诈;像躲避瘟疫一样躲避他们。这里有更多的信息:小心R值骗子。
  6. 黛安施奈德||#6
    在您的建议中,我们需要至少4.5英寸的Polyiso,您考虑到了我们已经在椽子内侧的1英寸的PolyiSo或者没有算成某种原因?
    我也想知道,如果你在绝缘的平坦/天花板部分上覆盖屋顶的整个外部,那么没有绝缘的山墙端墙?当墙壁/结束时,您是否会在峰值上获得“良好”的绝缘子。
    马丁·霍洛拉||#7
    黛安,
    对不起,我忘了你有1英寸的Polyiso。(你的原始问题相当长。)所以你可以从屋顶推荐中减去1英寸 - 你是3.5英寸。
    你猜到了你的山墙墙壁正确。如果您将倾斜的屋顶隔离,您还需要保留阁楼的山墙墙壁。
  8. 吉姆·梅里德||#8
    几个月前,你写了一篇关于电锯改装的文章。在其中一个链接中,有在原来的屋顶上建造的二次屋顶组件的图片。用绝缘材料填充空腔。这对戴安来说是一个实用又经济的选择吗?- 吉姆
    马丁·霍洛拉||#9
    吉姆,
    你是通过Harold Orr的改造。
    我不是玻璃纤维蝙蝠的粉丝,但Harold Orr使用它们进行外部改造。当这种方式使用时,它们仍然具有玻璃纤维贝蒂的所有缺点。
    如果它们在绝缘倾斜的屋顶组件中使用,玻璃纤维底座需要两个紧密的空气屏障 - 一个紧密的空气屏障 - 一个下方的空气屏障和一个上方 - 以及顶部空气屏障上方的通风通道。
  10. 吉姆·梅里德||#10
    罗苏或纤维素会更好地工作吗?- 吉姆
  11. GBA编辑器
    马丁·霍洛拉||#11
    吉姆,
    可能。但空中屏障细节的质量比玻璃纤维和矿棉之间的选择更重要。
