EPDM屋顶的滴E边缘
Jonny_H|发布绿色产品和材料上
我将EPDM膜(Carlisle SAT EPDM)放在低矮的(〜1.8:12 /9度)的屋顶上。I’ve seen plenty of details with various types of edge termination — generally the membrane is wrapped over the edge, secured with some sort of termination bar or drip edge, and in some cases an additional strip of EPDM tape covers over the top of the termination bar or drip edge. However, I’m having trouble sourcing the edge metal bits. I bought the membrane from a local branch of a roofing supply place (ABC Supply) but they said they don’t carry the metal. I found a company called Metal-Era which has a lot of nice stuff, but they just quoted me over $6 per foot for the most basic drip edge, which seems excessive [Notably they are set up to supply commercial jobs and basically everything appears to be custom-bent to spec, there’s not really standard parts — so their cost probably isn’t outrageous for what it is, but it’s a higher class of product than I need.]
有没有人想到要采购EPDM低矮屋顶所需的边缘金属的想法,或者这种情况是人们只是租用制动器并自己弯曲它?
  1. gusfhb||#1
    当我做屋顶时,ABC回来了
    EPDM现在在常规的建筑物供应场所更为普遍,因此即使是家庭独裁者也可能至少具有一种尺寸。
    我所在地区还有另一个商业屋顶服装,我从不记得这个名字的东西买了一些东西。
  2. gusfhb||#2
    只是查找它,HD在我当地的商店中有3英寸白色EPDM滴灌边缘
    https://www.homedepot.com/p/amerimax-home-products-c6-white-aluminum-Aluminum-drip-drip-ge-flashing-5573300120/202530736
    描述是错误的,但应该是正确的东西
    迈克尔·梅纳斯||#3
    如果您愿意,可以将常规的滴管与EPDM一起使用;通常看到的C3 Dripedge(商业3英寸)的唯一特殊之处是较短,平坦的腿,较长的垂直腿覆盖了典型的纤维或泡沫底层(这也是可选的)。
  4. gusfhb||#4
    常规的滴灌边缘具有纵向的肋骨,通常是边缘荷叶边,我不确定我是否想要橡胶上。
登录或创建一个帐户以发布答案。
最近的问题和答复
