地下室装修-绝缘层问题
布拉德·奥格登|发布一般的问题在
您好,感谢您回顾我的问题/困境。我正在完成我的未完成的混凝土浇筑地下室在我的2550平方英尺的牧场住宅建于2002年。根据GreenBuildingAdvisor的文章,我用2个″EPS直接粘在墙上的方法来绝缘我所有的墙。这部分我已经完成了70%。我已经利用罐装喷雾泡沫绝缘之间的似乎4'x8 '面板和特维克胶带。我已经修复了所有的地方,我有水渗入头发线裂缝的基础墙在过去。想想看,在一个月的时间里,我把绝缘材料固定在一堵从来没有水问题的墙上,结果发现了一小滩水。我最初的计划是将2个″EPS从地板搁栅顶部粘到地板底部。地板采用1个″厚硬泡沫与2个″墙体EPS对接。在1″硬质泡沫地板上加胶合板。 However, here is my dilemma, I have subscribed to the wisdom of having the thermal break and air sealing by utilizing 2″ EPS on the walls, and intended on doing the same with the 1″ rigid foam on the floor, BUT, after seeing the water seep through on a wall that previously never had any water issue I have realized that water is going to come in to the basement in some occasions. So if I did the sub-floor with gluing the Rigid foam directly on concrete basement floor then I am giving the water that gets into the basement through the walls no where to go. If enough water was to come in a particular spot and had no where to go, I suspect the water pressure could increase enough to begin penetrating the seems of the EPS, or even pop the insulation off the wall over time. Or if it does find a way to get above the rigid foam on the floor it would then be very close to plywood sub-floor and could possibly saturate bottom plate of framing. SO my solution that I have come up with mentally is to utilize a dimple plastic underneath the rigid foam, tuck it about an inch underneath the 2″ EPS on the walls. This way any water that comes in through the walls would be directed underneath the dimpled plastic. The little bit of air flow provided by the dimpled plastic would eventually allow the floor to dry or absorb the moisture through the concrete. OF COURSE this goes against the whole wisdom behind air sealing and creating a thermal break on the concrete basement floor ensuring no condensation. But I think this is the only way of ensuring water that occasionally comes in through the walls has a place to go without destroying the finished basement.
你们觉得怎么样?谢谢,很抱歉我的问题太冗长了!
  1. 布莱斯奈斯比特||# 1
    你的环境是什么?
    我做了一个酒窝垫板地板5年前,它已经表现得很好。酒窝垫,EPS,厚度,硬木。
    或者有各种预制的空间地下室地板产品,以“DriCore”地板为代表,有或没有绝缘。
    我还试用了一种产品https://www.radonseal.com/wet-basement.htm用于填充细小的混凝土裂缝(这是为了防止氡气体进入建筑物,氡气体主要是由于裂缝而不是其他原因泄漏的)。
    布拉德,
    装修地下室总是有风险的。装修地下室的第一条规则是,“如果你的地下室有进水的问题,在你开始保温或装修之前解决进水的问题。”有关详细信息,请参见修复潮湿的地下室.
    在像你这样的情况下,水坑靠近墙的底部,标准的解决方案是在地下室周边安装一个内部的法式排水沟。这个法国排水管通过穿孔管道连接到污水坑。该污水池排水到日光或配备了一个污水池泵。详情请见我链接的文章。
  3. 乔恩·R||# 3
    一个月后,我把绝缘材料固定在一堵从来没有水问题的墙上,发现了一小滩水。
    不足为奇的是,这些水分可能在积累之前就已经从墙壁上蒸发掉了。
    的确,如果你把墙水直接放在允许水流动的地板下,那么你可能不需要昂贵的室内侧周边排水管。水的分布和蒸发,或者在平板上开个小洞就足以把水排出。或者一个集水泵可以排出更多的水。如果你闻到了霉菌的味道,你可以稍微减压地板下的缝隙,防止异味进入生活空间。
  4. 乔尔chee||#4
    记住,你已经有效地降低了你的基础墙的温度,并且你使用了透气性好的隔热材料。水可能是凝结的,而不是你之前没有注意到的泄漏。
    马丁Holladay||# 5
    乔尔,
    你所建议的情形是极不可能的。
