GBA标志horizontal Facebook linkedin Email Pinterest. Twitter Instagram Youtube图标 Navigation Search Icon 主要搜索图标 视频播放图标 Plus Icon 减去图标 图片图标 Hamburger Icon Close Icon 分类
地热屋供气
丹尼斯vogt.| Posted inEnergy Efficiency and Durabilityon
I am trying to re-route my household fresh air intake to run under the ground and enter near the basement floor in order to warm it up in the winter and cool it down in the summer. I live in Wisconsin. I presently bring fresh air into the house constantly and route it to my furnace cold air return. For underground routing, I am concerned about radon gas and water getting into the tubing. I am also concerned about contamination of the air from the tubing.
丹尼斯vogt.
    Martin Holladay||#1
    丹尼斯,
    Your concerns are appropriate. Buried earth tubes have so many disadvantages that they are rarely installed these days -- and with good reason. Here is more information:Belgian Passivhaus is Rendered Uninhabitable by Bad Indoor Air。
  2. 丹尼斯vogt.||#2
    Thank you Martin,
    我阅读了这篇文章,至少部分地看到了该系统如何失败。
    I was considering running a pair of 4" diameter CPVC pipes (rated for potable water and covered with a screened rain cap) vertically downward until 6 feet deep and then running them horizontally for 15 feet except pitching them downward and then taking a 90 degree turn into the basement wall a foot above the basement floor. The CPVC joints would be glued. I was going to add a drain fitting inside the basement to drain any condensation from the summer. I was also planning on dumping some bleach/water mixture down the pipes from outside once a year to make it uninhabitable for mold. This design is affordable. Still, I share your health concerns. Assuming that water/mold is prevented, I am not sure about the CPVC being safe for the air.
    丹尼斯vogt.
  3. 杰西史密斯||#3
    您可以通过地面运行一个线圈,并在进入返回管道之前使用它来预热空气。可能有点不那么危险,但更复杂。安装HRV可能会更便宜。目前的系统是否会让你感到不舒服?房子的通风率是否正确?我所看到的大多数房屋都有通风率套装高......
  4. 丹尼斯vogt.||#4
    Thank you for the idea Jesse,
    我现在看看你的意思;将一些流体从进气口循环到地面。进入的空气将热升起来接触线圈。实际上,我唯一不喜欢的是我需要使用能量来运行泵。
    丹尼斯vogt.
  5. 丹尼斯vogt.||#5
    I measured the incoming air rate to be 75CFM, which is what I think is appropriate. The present system is working out fine. I am just trying to reduce the energy use.
    丹尼斯vogt.
  6. Sal Lombardo.||#6
    I was considering an "earth tube" or a version thereof as well Dennis. From what I've found websearching the issue, its not such a good idea after all. From what Jesse suggests, it sounds like a form of geothermal? I am not that knowledgable on such systems, but an underground coil that is used to heat or cool air sounds like a form of geothermal, no? If you look into it and find anything worth while let me know. At a minimum sounds like you'd be running a pump and a fan.
  7. Jan Juran||#7
    嗨Dennis:UltimateAir制作一个附件,一个12英寸水到空气线圈模块,它连接到其收纳仪200dx erv。该模块可以连接到地面回水/流体管,冬季预热和除霜,并预先改装。夏天凉爽和脱湿,进入他们的ERV。检查出来:http://www.ultimateair.com/Portals/92089/docs/6825_Water-to-Air-Coil-Module-Installation.pdf例如,55F入口水可以将室外进入的空气预热至31F进入ERV,缓解ERV需要进入除霜模式。类似地,50F入口水可以将95F进入的95F进入67F-72F范围内的进入ERV(参见上面的链接中的表PP。5和6)。水模块的水提供冷凝水排水。应对水/流体泵(2.5或5GPm为典型)和地环的安装成本来称量节能。
  8. JP Jon Pierce.||#8
    WONDERFUL!
    1995年在县机场,3200英尺的垂直boring with 3/4 U-Paired tubing delivered not less than 7 useable TOTAL cooling tons and 4% DEHUMIDIFICATION exchanging 80-deg office air with 52 degree boreholes x 240 ft depths + headers in 5ft trenches combined, borehole static water was ~ 40ft deep in a standard grouted GEOTHERMAL 98% RENEWABLE installation. the 1.1/2hp circulator was quite less costly allowing a barely comfortable work area during construction.
    从地球耦合 - 地面环路交换机(ECL,GLE,GTX,GL)的接口热能转移,用普通的福利器皿冷却,用于冷却和HW 23吨加热,略高于17辆净冷却吨(为45fw x 76air x 64rh x预期40-44普克,现场)。
    今天:在地面循环中实现体面节能的设计是在22英尺TDH WTR下的“井”,包括盒子中的HTPump线圈,允许1个泵送惠普与近26“Ahri-Rate-'tons'(HAH)”(HAH)“〜22+压缩机 - 在此进行比较...或者只是在直接地球管 - 流体冷却方面比较...或者只是靠近可用的直接地热冷却,最多1英寸SDR-11(不是SDR-9)〜2(2)X 245英尺的每次直接 - 全冷却吨,通过每个FANCOIL面对约2.1 / 2平方英尺的FT FIGTUBE x 3ROW x〜500 CFM。绝缘运行和橱柜和太阳能和热泵优质标准的密封管道至关重要。[每个净冷却吨的7-9 GPM较高,Wilo超级变量泵或类似于33GPM泵的东西,可在25英尺TDH WTR 500W下使用500W。由Pentair-Sta-Rite等游泳池循环器,有梦幻般的res和通信设备更好。
  9. JP Jon Pierce.||#9
    Please note any standard water in piping : Headers are for purging on occaision if your loops and headers are normally operating under 2.2ft per sec where almost all micro 'cling-ons' air bubbles clinging to smooth plastics, etc, are found that need then to be moved out of the piping at over 2.1-2.2 fps. Some 1/2" exchangers of piping coils have required over 2.2 fps.
  10. GBA编辑器
    Martin Holladay||#10
    Jon,
    你是缩写之王。
    “ECL,GLE,GTX,GL ... HW for ... GPM ...... GPM ... FT TDH WTR ... AHRI ... HAH ... SDR-11 ... WILO ... FT TDHwtr .... res和comm ... fps。“
    Wow.
    (WOW is an abbreviation. It stands for "what obscure writing."
  11. 专家成员
    Dana Dorsett||#11
    如果您只使用手机,而不是语音,你的STYR GTS PRTY TRSE。(这只是一个巧合的是,“Twitter”从“Twit”?? :-))开始
    为理解写作需要至少一些填充空白,否则很大的反应可以成为自我的注意事项(内疚,YER荣誉!)
Community
Recent Questions and Replies
