用隔热泡沫进行室内包装
约书亚特里|发布了绿色建筑技术在
你能告诉我,如果房屋包层实际上是服务的目的下泡沫板?
第二篇,我发在这里://m.etiketa4.com/blogs/dept/musings/where-does-housewrap-go,但我不是一篇文章,是几年前确定适当的礼仪。我一直在研究了大约一年,读每一篇文章和链接我能。目前项目爬行封装和隔离。更换3个外门和窗1(Innie)。我有一个报价,以ENCAPS从里面,但研究之后,我喜欢外墙外保温的想法。因为我已经预留出健康的预算,我试图做到这一点的最佳实践。I’m excavating to footer, clean stone and french drain, Carlisle 860 peel and stick up to and past rim joist 24″ onto house, 2 layers of 2″ of EPS staggered seams, a protective barrier 12″ below grade and 4″ above, firing strips and corrugated metal or stone veneer for aesthetics. This was an effort to ensure the sill and rim joist was air sealed. In a year or so when I do siding and the rest of the windows I will add the rest of the 4″ of foam up the wall. My original thought was the peel and stick up the walls and on roof, but in reality this may be a little too lofty for my goals and the time I’ll be owning the house. Plus it’s a 12/12 or 14/12 pitch, and the roofers I asked weren’t keen on 8″ of foam. So this brings me to my house wrap question, and it’s pertinent now because I am replacing doors and a window and flashing correctly. So if the housewrap serves a purpose under foam, I will do it on the wall that will be exposed. I just don’t understand the function. I originally thought you wanted a foam wall completely air sealed under foam. But in further research, that doesn’t seem to be critical, just the R value requirement for zone 5 to keep dew point exterior the sheathing (R-5 walls). Tyvek recommends their drainage wrap, to break capillary action if water does get under foam, I am just not sure it would perform. House wrap I think would allow me to ignore air sealing the roof, without causing moisture issues, vs peel and stick on walls and nothing on roof, correct?
如果没有缝隙,普通的房屋包装不能作为排水平面,而缝隙会抵消泡沫的绝缘性能;据我所知,它是蒸汽渗透性的,但即使是4″厚度的EPS泡沫将否定干燥到外部。那么,在这一点上,室内包装不仅仅是一种浪费吗?它的目的是什么?
    Dana多赛特||#1
    室内包装是用于大量水的管理,是一种排水平面材料,可以正确地与室内窗户搭接。使用皱褶型的房屋保洁物至少有一个很小的排水空间。这个微小的缝隙也会对流空气,提高外壳的干燥速度。
    在4“无表面ii型EPS是一个最小的ii类蒸汽缓凝剂(大约作为干燥的1/2”OSB的蒸汽渗透性,不是一个真正的蒸汽屏障。它允许季节性干燥,但不能快速干燥。缓慢的空气对流通过褶皱包装通道提供比泡沫更多的干燥能力。
  2. 约书亚特里||#2
    谢谢你的快速回答。我倾向于特卫强排水管,也就是皱褶的东西。这些东西会帮助房子更“密闭”的效率吗?
    此外,从页脚了过去边龙骨用于密封能力撕贴有什么想法?或将刷子施加膜和密封边缘龙骨足矣?
  3. 基思·H||#3
    Nonpro / diy免责声明。
    是/将你的护套被曝光?它是连续的胶合板/ OSB?如果是这样,气密性好,为什么不使用优质胶带(我喜欢ProClima TESCON瓦纳从475),以覆盖所有的接缝和罐装喷雾泡沫(送亲风格枪和罐)和填缝周围的任何穿透密封。临熟人告诉我,他们的密封用胶带护套缺口后有显着的鼓风门测试。
    正如Dana所说,抗天气屏障(WRB,例如特卫强)更多的是用于可呼吸的水管理,而不是气密性,尽管我肯定它有一些帮助。
    我会注意你的剥离和粘贴产品和刷敷膜,以确保他们提供的渗透性,你的组装需要的那些桁架末端。你要烫什么?这取决于你的组装和气候,对吧?
  4. Jon R.||#4
    > a间隙否定泡沫的绝缘性能
    但漏包的间隙很小,对泡沫的绝缘值影响不大。
    Dana多赛特||# 5
    关于皮’'stick, 4“EPS外墙的地基基础墙分层盘旋飞行蒸汽渗透到内部管理地面水分毛细作用从底部的基础的灌浇混凝土或卡耐基-梅隆基金会可能腐烂了窗台上的基础。Carlisle 860是一个真正的蒸汽屏障,框架墙需要朝着内部干燥,如果完全覆盖。
    要知道,EPS外墙与地面的接触可能成为白蚁和蚂蚁保护隧道途径。最好是安装基础的泡沫和覆盖昆虫敏感的框架墙泡沫之间的防虫屏障。此外,还需要闪烁引导DrainWrap散水出对在以上等级的一些点外。铜Z-闪烁的基础窗台做的都好。从铜的浸出闪烁是有毒的木穴居昆虫的肠道菌群。如果这是太多的热桥,铜包窗台垫片形成一个Z-闪烁可能工作。漏隙贝滕闪烁和上部的泡沫需求约为1/8" ,以确保长期排水功能以及为褶皱包装对流气流。空气膜,紧缩仍相当绝缘,但没错,这是一个有点的热桥。
  6. 约书亚特里||#6
    另外,我也想找到一个好的液体防水剂(这是困难的),因为我是从剥离扶着走,直接贴在cinderblocks ......会是附加的泡沫煤渣,然后剥更有效的方法和棒过泡沫,然后窝垫法国漏极和石回填?像所有的ICF视频我只是看着。
    每次我看到次级泡沫,它总是在防水膜外面??如何来吗?
    马丁·霍洛拉||# 7
    约书亚说:
    Q。“先把泡沫粘在煤渣砖上,然后剥离粘贴在泡沫上,再把酒窝垫粘在法式排水管上,再用石头填充物,这样会不会更有效?”(就像我刚刚看过的所有ICF视频一样。)”
    答:你所描述的将正常工作的方法。只要记住,你还需要安装一个产品来保护垫窝的上面级部分(像金属闪烁)。
    Q。“我每次看到次级泡沫,都是在防水膜外面吗?”怎么来?”
    答:有优点和缺点两种方法(把防水层后面的泡沫或在泡沫)。如果细节好,做工好无论哪种方式能正常工作。在你的情况,凹垫,排水管,以及石回填走很长的方式来确保你有一个很好的系统。
