GBA Logo horizontal Facebook LinkedIn Email Pinterest Twitter Instagram YouTube Icon Navigation Search Icon Main Search Icon Video Play Icon Audio Play Icon Headphones Icon Plus Icon Minus Icon Check Icon Print Icon Picture icon Single Arrow Icon Double Arrow Icon Hamburger Icon TV Icon Close Icon Sorted 汉堡/搜索图标
社区and Q&A
ROI for ERVs
beedigs|发布了能源效率和耐用性在
How to find out my ROI on each system? Carrier infinity system or mitsubishi vrf-erv system? Got quotes from both and one is going to be $10K more than the other; this is not an apples-to-apples comparison but I imagine I would still be paying a little more to get the VRF setup…I am hoping somebody can guide me on how to figure out whether paying 10K for the VRF system would be worth it. Climate zone 2 so cooling is mainly our need for most of the year.
加入建设科学专家的领先社区
  1. 沃尔特Ahlgrim||#1
    It is a very simple question with a very complex answer.
    There are so many variable what does your electric cost, how do you predict it will increase in the next 20 years, what would the money earn if you did not spend it on the more expensive system, your local weather, the R value in your attic , the R value in your wall ,How many square feet of wall face each direction, how large are your windows what direction do they face, how large are your doors what direction do they face, how much air leaks into your house and dozen more.
    The only real answer to build a computer model of you home enter all the variable and crunch the numbers for both systems.
    I used a free computer program called BEopt. I am guessing 20 -40 hours to do the training and build your model. It will draw a graph and showing what system used least and most energy and the one that cost the least to own and operate for 20 years.
    一般,如果你每4或5年移动,就像很多人一样,用最低前期成本购买该系统。
    https://www.nrel.gov/buildings/beopt.html
    培训视频
    https://www.youtube.com/playlist?list=PLHC0xDtkdjgec8QhVt7exJY3tpSLEFk-d
    Walta
    1. beedigs||#3
      我在观看教程的同时开始在Peopt软件周围玩耍,但我必须做错了,因为当我“运行”数字时,我没有得到任何图表。
  2. 沃尔特Ahlgrim||#2
    注意任何将设备和管道从阁楼中获得的系统将少25%才能运行。
    Walta
  3. 沃尔特Ahlgrim||#4
    Wild guess is you selected 3 or 4 types of windows or some other item and hit the run button.
    Now the program is busy running a model for each variable in 15 minute increments for 365 day using your weather data even the fastest computer will take hours to run several variables doing billions of calculation.
    You can change to once an hour it will run 4X faster but you lose some accuracy.
    I would hit run go to bed and look at the data in the morning. I would only a few variables at a time.
    Walta
    1. beedigs||#6
      谢谢沃尔塔!伟大的提示!
  4. Jason S.||#5
    Here's the wildcard I love[loathe] to throw into ROI calcs: what is the probable rate of failure for each unit? What is the cost of replacement when either unit ultimately fails measured in dollars, stress & my time? Do the brands have good service and warranty reputation? These factors often matter orders of magnitude more than specs and simple payback. They almost can't be quantified.
    By all means do the ROI calc, but then do the 'gut check'.
    1. beedigs||#7
      thanks for the tips!
Recent Questions and Replies
