GBA标志水平 Facebook LinkedIn Email Pinterest 推特 Instagram. YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon Audio Play Icon 耳机图标 Plus Icon Minus Icon 检查图标 打印图标 Picture icon 单箭头图标 Double Arrow Icon Hamburger Icon TV Icon Close Icon Sorted 汉堡/搜索图标
社区and Q&A
Minisplit location
Chris King|发布了Mechanicals在
Hi all,
Getting ready to order a Daikin ceiling mounted mini split and have some questions on its location to make sure I am going to be able to get even temperatures throughout the house.I am using the ceiling unit because my wife hates the look of the wall units and am going Daikin due to having a family member being able to get me the unit at cost.
I am picking the 1.5 ton unit to heat the section of the house attached in the layout PDF up until the blue line. The house was originally a ranch with a detached two car garage that the owners connected in a giant sun-room with all windows so for now I am focused on the main portion of the house. Though the rooms aren’t to scale, the overall measurements are correct.
1. Do you think placing the unit right before the hallway is a good spot for it? (red circle) and green circles are doors which will remain open.
我想把外面的压缩机放在我的屏蔽门廊上,靠房子(橙色圈),以保护它免受雪和元素。门廊是8'高,并且从2'到屋顶的屏幕。
谢谢你们。
边注:
I am in Ocean County NJ, zone 4A and picked the 1.5 ton because it is barely able to cover my needs right now as I am still in the early stages of energy retrofitting and when I am done I figure it can help with the sun-room as my wife eventually wants to remove the dividing wall.
File format File format
加入建设科学专家的领先社区
  1. GBA Editor
    克里斯,
    你的位置chosen for the ceiling-mounted indoor unit is logical. But if it is important to you to "to make sure I am going to be able to get even temperatures throughout the house," you are likely to be disappointed. It's important to manage expectations, especially if family members like to sleep with bedroom doors closed, and especially if this is an older house.
    For more on this issue, see无导管的拇指规则.
    I don't recommend that your outdoor unit be installed in a screened porch. It's important that the outdoor air have unimpeded access to outdoor air temperatures and air flow. That's not just my advice -- it's usually part of the manufacturer's installation instructions.
  2. Chris King||#2
    谢谢马丁,欣赏反馈。回到压缩机位置的绘图板。
  3. Expert Member
    Dana Dorsett||#3
    Even with sufficient air flow you wouldn't want the compressor in the screened porch due to the very high volumes of somewhat heated air you'd be getting out of it during the cooling season making the porch area less pleasant to hang out in. The floor of the porch is going to amplify the amount of vibration noise too.
    If the foundation is a full basement or crawlspace a 1.5 ton mini-ducted version mounted below the floor could work out favorably. Fujitsu's 18RLFCD mini duct unit has comparable output, and slightly higher SEER/HSPF numbers, and probably a wider modulation range.
    http://www.fujitsugeneral.com/PDF_06/Submittals/18RLFCD%20Submittal.pdf
    Daikin's CDXS18LVJU slim duct cassette has roughly comparable capacity & efficiency, if you're committed to Daikin equipment:
    http://www.daikinac.com/content/assets/doc/submittaldatasheets/skyair/sds-fbq18pvju-rzq18pvju9-rev-4-25-13.pdf.
    The key with mini-ducted solutions is to find somebody other than a HVAC hack to specify the ducts, who understands the limitations of mini-duct air handlers and how to design for low heating/cooling load houses. Many mini-split installers don't do ducts, and many HVAC installers don't do ducted mini-splits. To find the right contractor for mini-ducted units you may have to ask the distributor for references.
  4. Chris King||#4
    谢谢达纳,关于廊道的地板放大声音。我看到的大多数设置都有迷你分裂在混凝土垫上,这与我的门廊有什么不同的,因为它也是混凝土?我唯一可以假设的是因为它像门廊一样反对基础,但想要确定。
