GBA徽标水平 Facebook LinkedIn Email Pinterest 推特 Instagram YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon Plus Icon Minus Icon Picture icon Hamburger Icon Close Icon Sorted
社区and Q&A
模块化房屋设计概述
Mike Haskell|发布GBA Pro Help上
Hi All,
我的演讲可以在https://www.scribd.com/doc/258417069/House-Design-Overview-R3?secret_password=OGaqncE5yoiQ6ZKcEamI
我今年将在马萨诸塞州东南部建造一栋新房子。为了减少施工时间,我计划与模块化构建器一起去。为了控制成本,我正在充当GC,并计划进行HVAC安装,阁楼和地下室绝缘以及管道/接线连接。我仍在寻找模块化的建筑商,希望我能找到一个愿意设置房屋并使房子紧张的人,并让我完成其余的工作。
I am going for a Net-Zero ish build, with the heating/cooling handled by four MSZ-FH09NA mini splits. I am also going to include radiant loops in the basement slab,under the first floor, and garage slabs to be connected to a gasification boiler the following year ( would like to record data on heat pump only to determine cost effectiveness). The wood system might be somewhat overkill, but the house is on a large wooded parcel and I have a lot of trees to clear anyway.
Thoughts and sanity checks from the experience crowd here at GBA would be very helpful. As a way of saying thanks I would like to offer the use of my FLIR E8 IR camera to someone in the area who is looking for temperature data.
  1. GBA Editor
    马丁·霍拉迪(Martin Holladay)||#1
    麦克风,
    I'm not a fan of wood boilers. I belong to the "keep it simple" generation. If you want wood heat, install a wood stove.
  2. Mike Haskell||#2
    嗨,马丁,谢谢您的投入。我想避开木炉有几个原因(我们目前的房屋被木材插入物加热了90%)。我没有合理的炉子,我知道哪种炉子具有气化,房子里有一个炉子也意味着烟囱,而房子里的木头(我的妻子非常反对)。炉子的另一个问题是热存储,如果火不燃烧不会燃烧火!
    我的计划是首先只用热泵建造房屋,以了解它在几个月内使用PV系统的运作方式。与房子住了一点后,我可以将锅炉放入独立的棚子里。系统唯一必须在施工时放入的部分是平板中的PEX。
  3. Expert Member
    Michael Maines||#3
    麦克风,have you considered building without fiberglass and minimizing foam? There are drawbacks to both materials, well documented in the green building world and on GBA.
    我们建造具有镶板组件(墙壁,地板和有时的屋顶)的高性能房屋,密封并用纤维素隔热,并在被动房屋水平上执行。我们在您所在地区安装信封。在网站上查看我们的网站http://www.ecocor.usif you would like more information.
  4. 斯蒂芬·希希(Stephen Sheehy)||#4
    Mike. Check out Phil Kaplan' s blog published today for inspiration about modular buildings.
  5. Arthur Ledoux||#5
    麦克风,
    我在北岸做同样的事情。看一下他们专门从事节能建筑物的PB,并具有进行双螺柱/远程墙模块的经验。我要走非常好的房子路线,但他们为人类的栖息地做了被动房屋。祝你好运!
  6. Mike Haskell||#6
    Hi Arthur, How far along are you in the process? I would love to take a thermo image of your house with my IR camera. I am looking into the double stud walls now too. I would like to talk more about the modular houses if you had time.
    thanks
    -Mike
  7. Dirk Denzin||#7
    迈克说:“炉子的另一个问题是热存储,如果没有燃烧不会燃烧火!”。
    Not true, look into Masonary Heaters. They give out heat for about a day after the fire is out.
  8. Arthur Ledoux||#8
    麦克风,
    I am hoping to begin building in May(applying for permit next week.) I had originally planned to do a double stud wall but ended up redesigning it to a remote wall. My wall detail will be the following:
    Drywall(all their modulars are built using airtight drywall method)
    2x6 16oc致密纤维素
    1/2拉链
    Tyvek排水管
    2 layers of 2" xps or polyiso (whatever I can get cheaper from insulation depot)
    1x4绑带
    LP smartside
    I'd recommend calling PBS they will answer any question you may have and have tours almost everyday with an appointment.
  9. Len Moskowitz||#9
    We built a modular pre-certified Passivehaus in northern NJ. The first two floors are four factory-built modules, stacked two on two. The dormered attic was built on-site as was the poured concrete foundation.
    We prevailed on our modular home factory to double frame the walls, inner and outer 2x4 wall frames on a 10" baseplate, and to insulate the walls with densepack cellulose.
    The modules came with electrical and plumbing installed, but we installed the HVAC systems on-site.
    For heating and cooling we're using two of the 12k BTU Mitsubishi Mr. Slim ductless heat pumps, one for each of the main floors. We have a Zehnder ERV. They've all worked well over this first winter.
    有关更多信息,请参见本文:
    //m.etiketa4.com/blogs/dept/green-building-news/passivhaus-building-modular-way
    There's lots more detail on our Facebook page: Passive House NJ
Recent Questions and Replies
