Insulating a Cabin Floor
你好。我最近在纽约州的森林里建造了一个小型网格贴纸舱,让我的家人走出了越来越多的混乱,即我曾经爱过的国家已经成为......无论如何!
I have rarely ever had to build something that wasnt on a proper foundation. On the few occasions I have, the insulation process was subbed out to insulation contractors and I devoted my attentions elsewhere.
The cabin is on stilts. I have used ALL code Compliant methods and r-values throughout, mainly because they are what I know best. That is until the floor… the underside of the cabin is open. The floor being 2×8 joists, I opted to put r-19 fiberglass in the floor bays and covered with a good layer of plastic sheeting. I left a 2 inch airspace between subfloor and batt tops. I know it isn’t right but hell, the materials were free and I was on a budget! My floor stayed warm and comfortable all winter despite the lack of skirting. Wood heat is an amazing thing! In the spring I climbed under the cabin and discovered condensation had gotten caught by the plastic and the batts were one wet mouse house. I had expected rodent issues, it’s a forest, but the moisture was a problem.
This year I bought 3inch foil face rigid foam board and was going to install in place of batts and spray foam the seams for a good air barrier. I can only afford so much board. Do I insulate the floor again, the batts kept us perfectly toasty, and avoid the plastic or do I use the foam board around the perimeter of the cabin and secure with lattice or something? If the later, do I vent the space? Should there be plastic on the ground under the cabin? Each time I ask someone I get a different answer. Winter is back. My floors are too cold and I need to get the most out of money. Help very much appreciated!
To avoid condensation, either the vapor barrier has to be on the warm side of the floor, or there has to be roughly 30% of the insulation value as foam on the cold side of the barrier (the exact number depends upon your climate).
I think insulating the floor for a house on stilts is the right way to go. I'd go with faced fiberglass batts with the facing facing up. Then something mouseproof across the bottom. My preference would be 1/2" plywood, but I realize that's really expensive right now. 1/2" OSB would probably work, you'd have to be careful not to chip it and create openings for the mice, they only need a hole the size of a dime. Hardware cloth works too. So does Durock or similar cement underlayment board.
