Slab on grade and plumbing penetrations
I am looking for specific information about detailing plumbing waste lines for a slab on grade on Cape Ann (north of Boston, Zone 5A). I am concerned about sub-slab insulation, the air barrier, vapor barrier and general coordination of excavation, concrete and plumbing trades. I am familiar with Building Science Corporation’s recommendations for polyethylene location and “no fines” in the stone layer.
Thank you,
John Rockwell
Rockport, MA
Prior to the pour, tape the pipe penetrations to the plastic sheet, then put a piece of pipe insulation around each pipe that sticks up flush with top of slab. Later, if you want to, you can trim the pipe insulation below the slab a bit and replace with canned foam. There are a few useful details shown near the end of this documenthttp://www.metrowaterproofing.com/documents/STEGOW15.PDF
The 100K House folks used to have a very good page on using Stego wrap and how to seal penetrations, luckily the Google cache is still visible:http://bit.ly/vy8XvA
