GBA Logo horizontal Facebook LinkedIn Email Pinterest 推特 Instagram. YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon Plus Icon Minus Icon Picture icon Hamburger Icon Close Icon Sorted
社区and Q&A
Spray Foam Odor Help
Joe K|发布了General Questions在
你好,谢谢你看看我的帖子。我显然是新的,在这里不绝望。最近(上周6/12,13,14),我有一家公司将热质膜封闭和开放式电池安装到我家中。闭孔没有气味,但开放电池具有强烈的化学气味。我留下了窗户,有3个粉丝。该公司在所有2×4框架中置于封闭的细胞,2“在屋顶甲板上盖上6-8”(好吧,这就是他们所说的......我发现了许多领域他们短或瘦,他们正在回归它)所有2×6框架都有开孔。
Can anyone tell me where in the lower part of NY (Hudson Valley) I can find someone to do an air quality test for me. I dont want to sheet rock the house up with the odors still there if they are in fact harmful.
感谢任何输入。
Joe
加入建设科学专家的领先社区
  1. GBA Editor
    Joe,
    I don't recommend an air quality test yet. One thing that could be done is an investigation of the cured foam to see if there are voids, gummy areas, or anomalies that indicate an off-ratio mix. Otherwise, I recommend "watchful waiting."
    In case you haven't read it yet, here is a link to an article that might interest you:Spray Foam Jobs With Lingering Odor Problems.
  2. Don J.||#2
    Hate to be direct but Joe you are pretty much screwed... most likely
    不要忍受干墙,你需要刮掉它。气味可能会永远保持
    been there, done that, learned my lesson...
    yes, and you'll likely face a mountain of denial from all parties involved
    See my previous posts.....
  3. John Brooks||#3
    嗨乔,
    我在这里移动了第二个问题,因为它与你的原始帖子有关。
    (and I apologize to you for going "off-topic")
    Joe K wrote:
    “好的 - 所以我开始撕下一些臭泡沫的开放式电池泡沫,意识到泡沫人与应该在开放电池下方的闭孔中完全撕下我。有2英寸的闭孔....如果有3/4,我很幸运。
    我的问题是我独自离开信封,只要忍受它,或者我有人进来并撕掉它并寻求删除和闭合细胞的缩短的法律诉讼吗?
    I'm supposed to have R-38 in the roof decking. I'm lucky if I have R-24 or R-30 in some areas."
    David Meiland's advice:
    “我自己不会清除任何喷雾泡沫。致电承包商,让他有机会做对。如果这不起作用,请致电制造商。如果你开始自己拿出它,你会减少他们的机会将合作。不要破坏犯罪现场。“
    A question that still remains....
    留下安装的后果是什么?
  4. GBA Editor
    马丁·霍洛拉||#4
    Joe,
    If you have written documentation that describes the work you expected (2 inches of closed-cell spray foam), and if the contractor installed less than you specified, then the contractor has to do what it takes to fix the problem. Most contractors, when confronted by a homeowner who can document the fact that the work was not performed as specified, will do their best to resolve the problem.
    However, a minority of contractors refuse to resolve cases like this. If that happens, you could consider going to small claims court or hiring a lawyer.
  5. 理查德贝伯勒||#5
    From Green to Homeless: One Man’s Battles with SPF Insulation
    Jim Vallette 2013年6月20日2评论
    理查德贝伯勒of East Lyme, Connecticut, provides a great example of how one person can change the building industry (with a little help from the Pharos Project).
    After a bad spray polyurethane foam (SPF) insulation installation sickened him and his family, Mr. Beyer researched these products on Pharos.
    - 更多信息请访问:http://www.pharosproject.net/blog/detail/id/163/spf-safety-standards-vetoed?source=signal+blog ketserts& rutm_campaign=7ae6048c13-rss_mail_campaign& tutm_medium=email& utm_term=0_20455509_308757549#sthash.os5ycbx1。DPUF.
  6. 理查德贝伯勒||#6
    I hope your contractor has "Contractor Pollution Liability Insurance? Your first step is to verify the contractors insurance policy and the second is to make the claim. There are no published remediation standards for off-ratio spray polyurethane foam by any industry, government office or national building codes. We are the guinea pigs of industry for the 21 century. Your homeowners policy does not cover smelly foam so do not try to get them to make it right. It will not happen. The exclusion is "Gas and Workmanship".
    http://www.isopa.org/isopa/uploads/6marchisopapachs.pdf.
  7. Mary Sally||#7
    Joe
    Sorry, but your bad experience with Spray Foam SPF has happened to tens of thousands of building occupants and owners. I was seriously and permanently injured by the fumes at the school were I was teaching.
    一款良好的审皮医师,这款产品的专家,作证,烟雾剧集远低于您闻到它们的水平。通过“敏感化”增加对身体的损坏,您暴露的时间越长,从产品中脱气。
    我的鼻窦组织如此损坏,伤痕累累,必须在手术上被移除。我的喉咙,喉咙和肺部都被伤痕累累,导致嘶哑。最糟糕的是脑损伤。SPF中的化学物质被EPA认识到导致呼吸系统和脑损伤,特别是儿童。
    如果您需要有关嗅觉的意见,则应修改您的问题,以便询问与产品的烟雾相关的健康问题。咨询众多SPF类诉讼律师或个人伤害律师之一,以获得答案。
    在任何情况下都没有允许更多的产品,这将导致更健康的损害。不要自己删除此产品。它也不会消失。申请年后,房主对气味和健康问题有抱怨,要求将家庭搬迁到毫无戒心的买家。
    It is possible that this message will be removed, so the message has been copied and will be messaged.
Recent Questions and Replies
