碰撞nook的补充热量?
我们正在建造一所房子,在我们的厨房里有一个小小的4'x 6'碰撞。碰撞将在其中有一个展位,3侧有大窗户。它在房子的北侧。
这是位于角落的24 x 28 'great room. This large room will be heated with a mini split. The windows are good quality double pane vinyl, and we are located in Virginia, climate zone 4.
我们年纪大了,这是我们的退休家。我想知道我们是否会在所有这些窗户旁边的中冬季感到太冷。这是我们的用餐区。
有没有人有任何建议可以进行补充热量,以便在这个展台上保持温暖?(也许来自上面的辐射热源?)我们很快就会安装粗糙的电动,因此这是做出这一决定的好时机。谢谢。
GBA详细资料库
This might be a case where getting European style, triple pane windows is worth it. No one can know your comfort range, but I can tell you that we sit in the window sills of my house in zone 6 in the winter, and are perfectly comfortable. That's inches away from the window. But by all means, no matter what you decide with windows, rough in electrical for a cove heater or even a ceiling panel. It costs very little during construction.
如果你愿意分享,好奇很想看到你的地板?
这可能会让你更好地了解不适水平。如果有一个问题,辐射对我来说是有道理的。
https://www.payette.com/glazing-and-winter-comfort-tool/
Debra,
碰撞悬臂还是与房子的其余部分相同的基础?
+1在这里的三重窗格窗口,他们将有助于舒适。有美国和加拿大制造商可以制造一个良好的产品。尝试获得最大效益的1-3 / 8“全厚度类型,或者至少1-1 / 8”类型(这些是Igus的厚度,而不是整个窗口的框架)。7/8“三个窗格窗口不会在内部具有I89涂层的双窗格窗口中添加太多。
如果它是一个内置展位,我会考虑将电气辐射热系统放入展位中,这听起来像是您的计划。这将就像在你的车里加热座位一样。将开关放在展位附近,让您在需要时打开和关闭系统。如果不使用大量的能量运行,这应该有很多舒适度。
账单
Thanks for your questions and suggestions. Unfortunately, replacing our windows for triple pane ones is not currently an option. The bump out is above a closed, conditioned crawl space (not cantilevered). The windows have low E, U-factor .27, and SHGC .29. I've attached a copy of the floor plan for our great room with bump out.
比尔,我永远不会在展位里有一个内置的加热系统。我喜欢这个想法,但在暴露于太近的升高的磁场时,我有问题。但我会调查它。
Jon, I used that online tool you provided and plugged in my numbers the best I could. I couldn't find a way to submit a plan with 3 windows around a booth. But, with just one window, it said that our booth passed on comfort levels (just barely at our coldest temps, but reasonably well at our usual winter temps). But this was assuming we were one foot from the window (it didn't allow for closer positioning). So, we're a bit borderline at the coldest temps. Thanks for sharing that.
我认为我们可能在一些电动中粗糙,以便可能的天花板辐射加热器。但我想首先学习所有选择。
一个小的辐射热系统不应该在磁场的方式产生很大的产生,但如果你担心,有一个金属制造商切割一块钢板,以适合在展位座椅下方,然后在下方安装加热电缆。让你的电工将地线连接到钢板钢(可能不是必要的,但最佳额外的安全性无论如何)。钢板将有助于保护您免受加热电缆产生的任何磁场。我会使用1/16“温和的钢,这应该是非常便宜的。他们将围绕”1/16英寸“到最近的金属仪表,这将是近似的并且会很好。
钢作为磁屏蔽。这并不完美,但它会有所帮助,它比Mumetal或其他更好的东西便宜得多。钢材还将有助于充当加热电缆的散热器,并为非常温暖的温暖撒出热量。
如果您不想去辐射的电缆路线,我会伴随着Malcolm的建议将加热器放在桌子下方。热量升起,温暖的腿和脚比从天花板安装的加热器暖色的暖顶更加舒适:-)
账单
账单
Debra,
我建议将电阻加热器放在桌子下方,而不是从上面尝试和热量。舒适的脚和温暖烘烤。
Great suggestions! Thanks. I'll look into them.
