Getting the Right-Size Torque Wrench Head
I’m installing my minisplit next week. Problem in my robinair torque wrench kit only goes up to 29mm.
This unit takes a 3/4″ line. I’ve matched the flare nut to a 32mm socket in the garage. I’m using a jmf ez pull lineset with manufacturer provided nuts.
Problem is I can’t find this head open ended online. The yellow jacket adjustable only goes up to 30mm from what I’ve read.
How do guys torque this down to the appropriate specs??
Where can I purchase one that will fit properly.
I’ve checked test equipment depot and grainger.
Thanks
劳尔
https://www.amazon.com/1-2-DELUXE-METRICCROWSFOOT-W/dp/B076KKBKMG/ref=mp_s_a_1_31?dchild=1&keywords=1%2F2-Inch+Drive+Deluex+Metric+Crowfoot+Flare+Nut+Wrench+Tool+BY+JTC+1934+%2832MM%29&qid=1600571178&sr=8-31
Or similar, then
https://youtu.be/fBjr9-FDWYw
Buy a harbor freight torque wrench.
