GBA标志水平 脸谱网 linkedin. 电子邮件 Pinterest. 推特 Instagram YouTube图标 导航搜索图标 主要搜索图标 视频播放图标 音频播放图标 耳机图标 加上图标 减去图标 检查图标 打印图标 图片图标 单箭头图标 双箭头图标 汉堡图标 电视图标 关闭图标 分类 汉堡/搜索图标
利用中央强制空气在风扇中仅用于导管热泵全房空气循环的模式吗?
尼古拉斯Laskovski|发布一般的问题在
I’ve recently added a Mitsubishi Mini-Split (MSZ-FH18NA2) to our old (1870s) but decently renovated and well insulated 1800 sq ft. house (1100 1st floor, 700 upstairs) Sometime in the late 80s, a forced hot air oil furnace and duct work were installed. All things considered, our house layout is relatively well situated for a heat pump, but as with most retrofits, cold air pockets are going to exist, particularly in the bathrooms and furthest upstair bedrooms. The ductwork from the existing furnace, was actually done well and has good reach throughout the house with intelligent placement of returns, allowing for excellent whole house air circulation. Ductwork was partially rebuilt during the renovation by previous owners 10 years ago. We also have a wood stove which has the ability to heat our whole house, although constant wood loading is required. With the addition of the heatpump, I’m tempted to remove the old furnance, but I will not – at least not until I’ve fully vetted the heatpump – and for multiple other reasons, like one, it still works, and two, redundancy. But, I also have the mindset that I will try to run the oil beast as little as possible, all but for maintenance to keep the thing ready to go for whatever reason (heat pump breaks, selling the house, burning oil somehow ends up being good for the environment?).
我想让我的炉子调温器只打开鼓风机,不加热。原因是,利用现有的管道工作,把热空气从热泵和循环到冷袋,然后关闭时,温度稳定。我的炉子不是只有风扇模式,我的恒温器只有两根电线。目前,只有在有热的时候风机才会启动。从技术上讲,我可以更换一些电线(在炉子和恒温器上),但我不只是想手动打开风扇,我还想在温度下降时自动启动风扇。我也喜欢在需要的时候打开风扇的想法,只是为了在一年的其他时间循环空气,室内空气过滤,等等。
除了技术能力,这是个坏主意吗?我知道额外的空气循环将增加电力的使用,因为电扇和热泵工作更努力,但我有一个太阳能系统,目前产生了过剩,我需要找到一个体面的方法来使用电力。
我是复杂的事情吗?
旧房屋技术融化锅冗余效率低廉
    达娜·迪斯特||#1
    由于低温差异,将72F空气移动到62F室的62F室中的加热效率非常糟糕。它与炉子有意义,因为它在65F中占据了65°F并提供115-135F的空气(50F或更高的温差),但空气处理器使用的电量甚至可能不会弥补空气处理程序的热负荷诱导渗透。
    此外,75华氏度的空气甚至80华氏度的空气从登记处出来有风寒效应,没有什么像110华氏度的“温暖的夏日微风”从FH18出来。即使它使房间的温度高于预定的温度,它也不能提供确切的舒适。
    典型的炉空气处理器约为750瓦,如果在电阻加热器中使用,例如电板散热器将提供〜2500 BTU / HR的热量。在大多数情况下,在占用/空缺传感器控制下使用右尺寸(用于热负荷)电阻加热器,以便在较冷的房间内进行舒适性,仅在较冷的房间内进行舒适性,在需要的情况下提供舒适性。
  2. 尼古拉斯Laskovski||#2
    是的,现在用的是便携式小散热器。最远的卧室是客房,所以不需要供暖,除非有人过夜。在某种程度上,我们把它当作阁楼,几乎一直关着门。但是…难道整屋空气运动的想法,通过转换现有的旧管道炉鼓风机有一个自动/手动风扇模式(目前不是一个选项)与额外的整屋空气过滤奖励给我额外的点数?不然的话,我就得做这些看似不重要的事了。加入电话线的行列——这让我想到了我的下一个话题,我要怎么处理我所有的旧电话插孔?环绕声吗?
    达娜·迪斯特||#3
    如果你想通风,就通风,但不要把随机不受控制的渗透当成通风。在某些情况下,为了将通风空气从已知源混合和分配到其他房间,一个更大的管道系统的负载循环有时是有用的,但通风空气混合和分配所需的负载循环非常低——每小时最多几分钟。所以,如果你在你最关心的房间里安装一对Lunos,然后设置一个值班循环器来运行空气处理程序,每半小时运行1-2分钟,至少会有一些通风空气分配到所有的房间。
    如果您希望使用更多的电源来吸收多余的光伏输出,请购买电动汽车(真的!)。在我的地区,一个良好的日产叶子状况良好不是很贵,而且它是一个比外面看起来更大的车程。范围是有限的(特别是在寒冷的气候中的冬季),但大多数家庭已经让延伸技术的范围被称为“另一辆车”。在冬季,当叶子的范围性能最差时,热泵已经使用了可用的太阳能输出的好块,但在肩部季节和夏季,它非常好。对您(和地球)的净利度将比使用在低温差异下的低效空气处理程序上使用它来更好。
    电话接线是漂亮的轻型责任,而不是用于移动大量的电源 - 您不会运行一个潜水机,其中任何接近体面的保真度。在无线时代 - 所有现有的家电接线可能只是废铜被回收。
  4. 尼古拉斯Laskovski||#4
    已经有一辆Volt了!我们正在计划为管道系统提供葬礼服务。
