墙体保温-新建
Edi (Edwina)和Stev|发布一般的问题在
你好。我们已经发送到这里的知识渊博的人从花园网家园建设论坛。我们将在盖斯维尔市2A区建造。国家最低绝缘规范为R15墙和R30天花板。过去在佛罗里达用同样的R来建造,我们想要提高R值。关于我们居住地区的历史,我们曾在一些恶劣的气候中生活过。从海拔8000英尺的怀俄明州科迪到北部亚利桑那州沙漠,南部阿兹沙漠,南部潮湿的佛罗里达州。我们建了三所房子。一个到佛罗里达的代码(萨拉索塔),一个在菲尼克斯Az和一个在科迪威,这两个超过了代码绝缘,使每个更舒适和极低的电力成本。(电力公司)。 We again want R30 walls and R40 ceiling. These numbers have served us well in both 110 degrees to minus 40 degrees. This time will want concrete clock build as the 1967 home we live in now has been undamaged through 2 hurricanes that demolished the stick home next door and the stick home three doors away, while each neighbor’s block home was undamaged except for neighbor’s oak tree that fell through the roof. Irma a few months ago did much damage in our semi rural neighborhood but our block homes stood. Also termite consideration. Due to concrete block build which this house has only 1×3 inch on interior side with no indulation- just drywall. We are wondering how to get the R value we want- even 2×6 studs will not allow batts 7nless we are not aware of a higher R value product of batting. Spray foam does not seem to be as effiecient as first thought when it first came out. Please respect our want of higher R values. We have built two homes above minimum required code and the comfort is so much more!! Monthly electric bills were next to nothing. What would you suggest to achieve this R with a concrete block home. Wife has severe asthma. Thank u.
    Edi和Stev,
    1.您要求我们“请尊重我们对更高r值的要求”,我将照做。然而,我觉得有责任告诉你比在佛罗里达,投资R-30墙是不划算的。你可以通过指定高性能的窗户来获得更好的投资回报,或者用你原本用来升级R-15到R-30墙的钱来购买光伏系统。
    2.也就是说,这里是美国,你可以建造你想要的房子。
    3.通常绝缘混凝土砌块墙(也称为CMU墙- CMU代表混凝土砌块单元)的方法是用刚性泡沫。要达到R-30,你需要大约8英寸的EPS,或6英寸的XPS,或5英寸的聚苯乙烯。绿色建筑通常避免使用XPS,因为它是用一种发泡剂制造的,具有很高的全球变暖潜力。
    4.硬泡可安装在墙体内侧或外侧。从建筑科学的角度来看,外墙是首选。甚至可以把泡沫分开,在外面放一些,在里面放一些。
    5.您可能想要考虑使用EIFS。大多数EIFS承包商不会想要安装8英寸的硬泡沫,但你可能会幸运地找到一个同意安装5英寸的。EIFS是外部硬质泡沫和合成灰泥的结合。
    6.你可能想要考虑使用绝缘混凝土形式(ICFs),而不是混凝土砌块墙。大多数ICF制造商生产的组件的r值低于R-30,但少数可以实现你想要的。一家名为Logix的公司生产高r值icf。下面是一篇提到Logix ICFs的文章的链接:新绿色建筑产品- 2009年1月.
    Dana多赛特||#2
    螺柱之间的R30与R30连续绝缘不同。在考虑到通过木材传递的热量后,框架的热桥接将其降低到~R20“整面墙”。
    使用混凝土砌体单元(CMU)墙壁,您还可以从热质量中获得显著的好处,提供更高的舒适度和更低的能源使用,但只有在CMU的外部的大部分绝缘。把绝缘放在内部隔离内部的热质量,减少效益。
    要达到类似的全墙R的连续绝缘,需要在外部使用3-3.5英寸的硬质聚氯乙烯,但要达到类似的能源使用和舒适度,只需要2英寸或3英寸的EPS。r值只有R12-R13,但它是一个连续的R12-R13,热质量是100%在热包络内,缓和温度波动。
    或者,用最小ICF(绝缘混凝土形式)的钢筋浇筑混凝土建筑,在热质量的两侧放置2“EPS,它比CMU墙更坚固抵抗飓风。一些供应商从2..每边25" EPS,其他为2.5"
    在区域2的最小“质量墙”是R6,如果至少一半的泡沫在外部,使2“聚氯乙烯或3”EPS外部泡沫2x代码最小,和2“+ 2”ICF接近3x代码最小。即使在中央AK, 2.5“+ 2.5”的ICF也会超过最低标准。
    在类似的情况下,在屋顶平台上方使用5”(R28.5-R30) 2磅的屋顶聚脂,以及“冷屋顶”薄膜或瓦屋顶,其太阳反射指数(SRI)大于50,将比阁楼地板上的R60要好很多。FL的通风阁楼没有任何意义,因为它将更多的水分带入建筑结构,而不是净化。通风阁楼也相当容易屋顶甲板在飓风的风力下失败。在没有通风的阁楼中,为了使阁楼内的管道和空气处理装置获得良好性能所必需的细节大幅下降,产生了比通常更高的整体系统性能。
