可以应用于现有金属屋顶的冷却液?花费幸运的建筑。
Amelia Quinney.|发布了能源效率和耐用性在
试图冷却我的建筑。零售业务的15岁的老金属大厦。
  1. Nate G.||#1
    我收集这是一种没有绝缘的金属结构?什么是气候?它只是热,还是感冒了?
    马丁·霍洛拉||#2
    阿梅利亚,
    如果您的建筑空调,则需要绝缘。代码需要绝缘。
    If you have adequate levels of insulation -- at least code minimum insulation, which in most of the U.S. is either R-38 or R-49 -- between your hot roof and your ceiling, then you'll have enough insulation that you don't have to worry about your roofing temperature.
    您也可能通过您的窗户获得大量的热量增益。
