膏药与稻草包绝缘的外墙最好的方法是什么?
驯鹿叶|发布了绿色建筑技术在
我们想知道它是否直接在2“砂浆上直接涂抹在保护稻草包或者如果我们应该使用毛茸茸的胶合板,我们将在其中修理屏幕以放置石膏。它会增加空气差距,使得墙壁可以变得更好,但我们不知道它是否值得。
专家们想什么?
    哔叽,
    您可能希望查看该主题的GBA文章:稻草墙。
    您的问题的简短答案:此问题没有达成共识。每个人都同意的要点是让墙壁干燥至关重要。这最好用宽屋顶悬垂和一个基础,使大块的底部高于等级。
    在那篇文章中,我写道:
    "While some straw-bale builders apply plaster directly to the straw bales, Straube recommends attaching chicken wire or wire lath to the bales before plastering. “I want metal mesh in the plaster, even if it’s only light chicken-wire, for a bunch of reasons,” says Straube. “The main purpose of the mesh to keep the crack sizes small.” Chicken wire is attached to the bales using U-shaped pins poked into the bales or wires that go all the way through the bales; this is done with the help of a tool called a “bale needle.”
    “Laura Bartels建议使用鸡丝。”除非在结构上,否则我们通常会避免使用金属网格,“门尔斯说。”鸡丝或更强的高地震区域需要,但除了这些案例之外,您将主要找到膏药准备涉及在角落,材料过渡和框架或其他材料上加强。“
    “传统的抹灰技术需要三层石膏:刮刮涂层,棕色外套和一层涂层。膏药的总厚度通常在1英寸之间。和1/2英寸。
    "If you don’t want a stucco exterior, you can install any type of siding you want. However, it’s essential that the exterior side of the straw-bale wall be plastered, even if you later install furring strips and wood or fiber-cement siding.
    "“It’s very easy to put furring strips on,” says Straube. “One way is to install a scratch coat of plaster, then install your furring strips screwed to the stucco, and then install another coat of plaster between the furring strips. A better way to do it is to install two coats of plaster and then install the furring strips, shimming as needed, with Tapcon screws. The plaster will hold the Tapcons.”
    “Mark Piepkorn喜欢草捆墙上的​​Rainscreen差距的想法。”经验丰富和知识渊博的草捆建造者的一般共识表明,外部熔覆[在Rainscreen Gap]的外部熔覆比灰泥在几乎所有情况下单独表现,如果正确实施,“Piepkorn写道”。
