GBA徽标水平 Facebook LinkedIn 电子邮件 Pinterest Twitter Instagram YouTube图标 导航搜索图标 主搜索图标 视频播放图标 加上图标 减号图标 图标图标 汉堡图标 关闭图标 分类
Why vent in an unvented roof design for snow region?
In Joseph Lstiburek’s book ‘ Builder’s Guide TO Cold Climates ‘ ,in discussing unvented roof designs, he says ” In extreme snow regions it is necessary to add a vented air space between the roof cladding (shingles) and the rigid insulation to flush heat trapped due to insulating value of the snow…”
为什么壁板的加热需要排气?凝结?冰坝?
  1. GBA编辑
    马丁·霍拉迪(Martin Holladay)||#1
    布莱恩,
    潜在的问题是冰筑坝。深,毛茸茸的snow acts as insulation. If the snow is deep enough, it can allow melting of the bottom layer of snow; when the water flows down, it encounters the eaves, where the roofing is colder, and freezes. The ice at the eaves gets thicker and thicker, creating an ice dam.
    如果您在绝缘层和屋顶护套之间包括一个通风通道,则冷却屋顶护套和屋顶,减少冰坝的机会。
    有关更多信息,请参阅Prevent Ice Dams With Air Sealing and Insulation。
  2. Aj Builder, Upstate NY Zone 6a||#2
    Moisture is a problem too here in the Adirondacks with anything except spray foam.
    达娜·多塞特(Dana Dorsett)||#3
    马丁(Martin)正确 - 您需要雪的R值旁路,以防止其变成冰坝,如果屋顶上的深雪单书是常态。
    一场大暴风雨过后,我的屋顶有多达4'的雪,在背风方面,它具有相当大的R值。就我而言,我必须将其铲起到少得多,以限制这些事件后的ICE-DAM风险。
  4. 布莱恩·德·格鲁奇(Brian de Gruchy)||#4
    感谢Martin和Dan的及时回复。我特别喜欢链接“防止冰坝...”和许多博客。我位于蒙特利尔北部的劳伦斯人,第8区,降雪 +4feet(由于天气交流而随后融化和冷冻,散布着冰层)。显然,屋顶通风是绝对必须的。
    马丁,为什么您偏爱山脊通风孔而不是山墙通风口,因为后者似乎正常?在我所在的地区,最重的是用最大通风孔(通风最大值)代替山脊通风口,因为它们在深雪中的工作效果更好。
    我认为,仅提到我更成功的绝缘工作之一是在阁楼地板上吹2英寸的闭孔泡沫,并用16英寸的纤维素涂上底层。这是去年春天完成的,这个冬天将讲述这个故事。
    欢呼,保持良好的工作。
  5. GBA编辑
    马丁·霍拉迪(Martin Holladay)||#5
    布莱恩,
    研究表明,当拱腹通风口与山脊通风孔配对时,会发生通风阁楼中最好的空气流量。但是,此广泛的声明需要获得其他一些陈述。
    In areas of deep snow, it's possible that ridge vents will have reduced air flow when the ridge is covered with snow. Whether this temporary situation matters is an issue of debate.
    In general, attic venting matters much less than most people think. The three most important things you can do to reduce ice dams are (1) remove all heat sources from your attic, (2) seal air leaks in your ceiling and thermal bypasses into your attic, and (3) install thick insulation on your attic floor.
    重复:阁楼通风并不重要。
    根据建筑科学家威廉·罗斯(William Rose)的说法“一旦您将所有从下方通向阁楼的开口密封了,纠正了管道,并在阁楼上安装了一块漂亮的绝缘层,那么一个通风策略与其他任何一个一样好。山墙排气和山脊排气都很好。用挡板排气的拱腹很好。组合很好。如果屋顶的一部分有很多排气,其他部分几乎没有或没有,那么大多数人也会同意这也可以。但是,电动排气是嘈杂而昂贵的。”
  6. 布莱恩·德·格鲁奇(Brian de Gruchy)||#6
    Hi Martin,
    我无法就所有要点更加同意。但是,在高雪中,这些最大通风孔位于山脊上方2英尺处,是安静的{No运动零件},比建造山脊通风口便宜,价格便宜,价格为100美元,并且不会阻挡。
    By the way, I'm not affiliated to this company in any way.
登录或创建一个帐户以发布答案。
Community
最近的问题和答复
