Try out this app for mobile phones. I built it at widgetbox.com using the free site. It will be available for the next couple of weeks at which point, it will either go away or I’ll pony up the cash to buy a subscription.
Bookmark this link on your iPhone or Android phone and you’re mobile:
http://wbxapp.com/gba-blog-feed
if (WIDGETBOX) WIDGETBOX.renderWidget(‘3446104f-73c4-4e47-b2b4-dcc1169d8617’); Get the移动应用徽章widget and many othergreat free widgetsat小部件箱呢没有看到小部件?((More info)
Let us know if you use it, if you would continue to use it, and how it works.
Dan
Weekly Newsletter
Get building science and energy efficiency advice, plus special offers, in your inbox.
7 Comments
应用程序not working correctly.
Dan
The app is not working correctly on my iPhone, it does pull up the blogs but I can only see the first paragraph or so. Then entire article is not loading. I saw the new blog this morning by Martin on it but only the first 4-5 sentences are viewable.
应用程序
顺便说一句,我经常通过Safari在iPhone上拔出GBA博客,应用程序的想法很好,但它并没有给我任何我尚未拥有的东西。好吧,也许更快一些。
I tried to download the app,
我尝试下载该应用程序,似乎无法正常工作。可能是我阅读条形码的应用程序。
it's sort of lame on my android phone too
In order to read the full article, you need to click the title, which takes you to the main site and at that point, why is the app needed?
Article
On my iPhone, even when I click the article title I only see a few sentences, maybe the first paragraph. I cannot see the entire article.
works fine in a browser
I'd vote for spending money on adding details to the detail library rather than adding a smart phone app. I'm happy with seeing the data on my Droid Browser and I-pod (though my I-pod got stolen recently so I'm stuck with the Droid at this point)
Details I want to see: alternative foundation systems including CMU block, pier/ post and curtain, ICFs and Superior wall as well as that concrete-foam-concrete system Riversong uses. Non-foam, double wall data. Climate consultant 4 read-outs for various wall and roof scenarios, thermal photos of various air tightening strategies,
Details
Mike,
我在论坛中添加了一个名为“计划评论”的部分。我认为GBA的贡献者可以发布细节 - 就像您的双赛墙一样 - 其他人可以批评他们。
After details pass muster from the crowd, maybe we can find some budget for formal drawings.
I suppose a wish list could be a good place to start...
I was just fooling around with the app--if I could make a useful little widget quickly and easily, then maybe it was worth the effort.
应用程序arently not.
感谢您的输入,
Dan
Sign up Log in
