凯瑟尔屋顶的凝结被改造?
你好GBA社区,
我肯定的是新的论坛,我希望你不会太难。我已经阅读了在天花板界面凝结的其他论坛,但我没有觉得应用于我的情况。开始了:
I’ve recently inherited my mother”s house and ripped down all of the ceiling tiles and drywall to remodel. The home has cathedral ceilings (in other words, the outer tar and gravel roof, tongue and groove wood planks, a 2×10, and tongue and groove on the inside ,in that order). The old insulation in the roof was worn down and settled beyond salvage, so in the course of electrical we cut misc. holes in the tongue and groove to pull out the old dryall and install new R-19 24″ kraft faced batts.
Let me also mention that I’ve also removed the A/C unit and heater
我们非常兴奋,所以最终完成电气!我没有时间做干墙,所以我已经签了它。
Well, when they were installing the drywall they called me over to tell me some of the insulation was wet. I was curious as to if it was a roof leak or condensation, so I went on the roof with a hose and soaked the entire area at all different angles for an hour. No leak. It rained the next day, no leak. So I told them to button up the roof and move on, that it must just be a small amount of condensation.
承包商今天给我打电话,告诉我,梁(椽子2x10钉在整个房子里水平运行的三个2x10)是潮湿的,它正在制作干壁湿润。我去了屋顶,检查了一些焦油和砾石松动,但不足以浸泡到房子的末端(〜75英尺)。我附上了一个湿斑的图片,但在不同房间的顶部屋顶线上有至少5个斑点。
这些是我的想法:
1, There are soffit vents but no ridge vent – doesn’t this counteract the ideas of either venting the attic (would need a ridge vent) or unvented attic (with the soffit vents)?
我在想如果有任何屋顶泄漏,我们就会注意到当干墙下降时的水量(在我们正在做电气时约3个月)。
3.如果实际上是凝结,那么A / C会将空气改变这个问题吗?
How would i fix this? Could I cover the soffit vents and the problem would be fixed?
任何帮助都得到了赞赏!!
顺便说一下,我在路易斯安那州东南部。
GBA详细资料库
由气候和房屋部件组织的一千个建筑细节的集合
本,
1.由于您有一个焦油和砾石屋顶,我假设屋顶平坦或非常低。
你指的是“阁楼” - 这是绝缘顶部和屋顶护套之间的非常浅的空间吗?或者是别的吗?
3.拱门通风口通常不与低沥青焦油和砾石屋顶一起使用。
你有一个空中障碍问题,你选择了错误的绝缘。玻璃纤维BATT无能为力减缓空气流量。温暖,潮湿的室内空气正在进入您的椽子托架,并在屋顶的底部上冷凝,然后滴下并浸泡其他建筑部件。
5.您应该用深层纤维素绝缘层隔离,安装在空中屏障上,所有天花板穿透仔细密封,或用喷雾聚氨酯泡沫。
Hey Martin,
1.是的,屋顶是2/12间距。
我对参考阁楼的道歉,2x10的两侧都有简单的距离和凹槽。没有任何形式的阁楼,只是一个小空域。
3. Exactly the answer I was looking for as I was curious as to why they were there. I will attempt to get rid of them.
4.我假设空气的放缓将从绝缘形成的口袋发生并产生停滞空气。我猜这不像我想要的那样发挥出来。
5.当您提及仔细密封的所有天花板渗透时,这可能是通过胶带和搅拌所有干墙关节来进行的吗?或者这是不够的?我只是看起来像巨大的麻烦一样扯下任何干墙,我试图找到避免它的方法。
本,
你不能使用干墙泥来密封空气泄漏。您需要喷雾泡沫,填缝或垫圈。
玻璃纤维贝蒂不会在没有空中障碍的情况下工作 - 理想情况下,绝缘的各个侧面都是一个六面的空气屏障。
有关空中障碍的更多信息,请参阅:关于空袭的问题和答案
