低高度阁楼的密集纤维素?
戈登B|发布计划评审在
1951年建造的一个房间的屋顶将被密封,绝缘和重新落下(北部区域5A,差不多6)。三面斜坡约三英尺,直到斜坡符合构成大部分屋顶的平坦部分(阁楼横截面.jpg)天花板是膏药,穿透将密封,聚裂板之间的关节在周边附近使用compensate for the lower height will be staggered and sealed, air baffles allowing 2 – 3″ of air flow beneath the slopes will be installed, we’ll leave 2 – 4″ of space under the flat roof for ventilation but the rest (about 24″ under the ventilation space under the flat part + whatever will fit over the polyiso) will be filled with cellulose (Proposed R Profile & Materials.jpg). The flat part of the roof will be re-built at a very slight angle so water doesn’t pool and Ice & Water Shield will be installed. I’m aiming for a pseudo Passive House structure that is durable.
空气密封对于冰镇坝预防和一般效率非常重要,但我读到了超紧的旧房屋不可能。Fine Home Building published an article (by Mr. Holladay) saying “When blown-in insulation is installed in a closed framing cavity, it’s possible to achieve higher insulation densities than can be achieved on an attic floor… In a closed cavity, cellulose should be installed by the dense-pack method—that is, to a density of at least 3-1/2 lb. per cu. ft.” Dense pack provides a partial air barrier too.
但是这个简短的阁楼”(29身高max),也许认为这是有意义的一个封闭的腔,并使用密集的包装上面纤维素和polyiso——包装的内部空气挡板,留下2 - 4”在平屋顶的通风空间。这将增加一些R,并将赋予部分空气屏障的致密纤维素的房子,需要它所能得到的一切帮助。
一般来说,在使用高密度填充的纤维素时,“纤维素”在“建议的R Profile & Materials.jpg”中看到的水分、绝缘值、对流等方面是否存在问题??
如果来自那些角度的声音,也许有结构考虑因素。I don’t want any chance of plaster between joists sagging, bowing, etc. I can’t see if nails or screws hold the board to the framing but do know the boards are 16″ wide (can’t tell know how long). Assuming the weakest scenario – nails instead of screws and boards of unknown strength, is it obvious the plaster ceiling can hold 7.6 lbs per square foot (2 cubic feet high x 3.8 lbs cellulose/cu. ft. = 7.6 lbs over each sq. ft, assuming an overshoot on density to be safe) without bowing??? Or is this a question someone like an inspector or engineer should see in person???
如果一个密集的封闭式短阁楼是一个好主意,它是技术上可行的 - 在椽子上附着胰岛素,然后填入下面的大面积???其他密集包装这个空间的方法?
提前谢谢你。
    戈登,
    当你把纤维素堆在阁楼的地板上时,这堆纤维素的底部会受到顶部纤维素重量的压缩。最上面的几英寸会蓬松一些。堆得越厚,对底部的压力就越大。
    如果您计划安装20至24英寸的纤维素,则松散填充和致密的纤维素之间的差异并不重要。你的r值很高;我不会担心额外的R-1或R-2从密集包装中获得。
    听起来你会注意空气密封,所以我不认为归因于空气密封的空气流速的减少会产生大大差异。
    所以这个问题不是很重要。但是,我来回答你的问题:如果你想要密集包装区域,只有一个人可以告诉你它是否可行,那就是你选择的承包商。每个承包商都是不同的。一些纤维素承建商有大量的密集堆积经验,而另一些则没有。
    所以,问你的承包商。
