GBA Logo horizontal Facebook LinkedIn Email Pinterest 推特 Instagram YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon Plus Icon Minus Icon Picture icon Hamburger Icon Close Icon Sorted
社区and Q&A
Foam under slab details
dsmcn|发布GBA Pro Help上
New residential construction, Zone 4A, slab on grade with attached garage. Three questions:
1. Most builders around here pour the entire slab flat; in other words, no slope to garage door and no step up into the house. Is this an okay practice?
2.我打算将2½英寸的泡沫纸放在板下方,以进行R-10。是否有任何令人信服的理由继续在平板的车库部分下继续泡沫(不会有热中断,平板将是连续的)。
3. What is the detail for continuing the foam below bearing walls that will be supported by a thickened slab?
感谢您通过本网站提供的所有资源和支持。
  1. Expert Member
    MALCOLM TAYLOR||#1
    大卫,
    1) I don't know which code you are under but ours mandates that attached garages have both a slope to the overhead doors and a sill between the garage and house.
    斜坡的原因是显而易见的,因为您将大型湿物体带入其中,并且它们流失了很多水。
    除了防止水进入房屋的其余部分外,门槛还是许多代码要求的一部分,以限制排气气体的扩散到住宅中。在这里,包括空气密封和自闭合铰链在连接两个空间的任何门上。
    2) Is answered above. A continuous slab isn't a good idea.
    3) Foam is available which can withstand a variety of compressive loads. You can run it continuously under the thickened parts of your slab. Some people are uncomfortable placing the load-bearing portions of their house on foam. If you feel that way, the energy penalty for leaving out the foam under a couple of walls is very small.
  2. GBA Editor
    马丁·霍拉迪(Martin Holladay)||#2
    大卫,
    Malcolm gave you good advice. The garage slab should be poured separately.
    某些车库平板不是将平板倾斜到门上,而是设计到板块中央的地板排水沟上。
    When I built my garage, I placed the slab on a solid base consisting of compacted gravel (with fines), followed by 4 inches + of crushed stone. The crushed stone was raked and shaped for a thickened-edge slab. The rigid foam was installed on top of the crushed stone, conforming to the slope creating the thickened edge. I though this would be trickier than it was; it was fairly easy. You can use some tape to hold the foam in place if needed.
    因此,我的平板边缘下有泡沫。您可以做到 - 但是如果您担心,请与工程师交谈。
  3. STEPHEN SHEEHY||#3
    Another reason for a step up from the garage is that gasoline fumes are heavier than air. In case of a spill or leak, you don't want fumes flowing under the door and into the house.
  4. vtcaleb||#4
    我正处于在格洛弗(Glover)的房屋和半独立式车库中完成混凝土的边缘。我的挖掘机为车库提供了一个增厚的边缘板,我想将其隔离以调节内部的温度。我喜欢您对车库的描述,您是否可以详细说明您使用的泡沫厚度以及是否还有外围泡沫?
    Thank you,
    Caleb
  5. GBA Editor
    马丁·霍拉迪(Martin Holladay)||#5
    Caleb,
    我的车库在混凝土板下面有2英寸的水平刚性泡沫,在平板周长时有2英寸的垂直刚性泡沫。
  6. dsmcn||#6
    请澄清。
    马丁,how do you keep the trap in the floor drain from drying out, especially during dry seasons?
    Secondly: Malcolm and Martin, I would of course install a good exterior threshold (I prefer bumper thresholds); the question is whether a riser is necessary?I.e. is it necessary to have a step up from garage to house; and if so, how high?
  7. GBA Editor
    马丁·霍拉迪(Martin Holladay)||#7
    大卫,
    My floor drain is not connected to a septic system or city sewer system, so there are no smells to bother me. A dry trap causes no problems.
    The two methods I have heard of for keeping traps from drying out are:
    1. Pouring a little water down the drain when it begins to smell.
    2. Pouring a little water down the drain, followed by a few tablespoons of mineral oil or vegetable oil to reduce the evaporation rate of the water in the trap.
  8. Expert Member
    MALCOLM TAYLOR||#8
    大卫,I'll reiterate: you need to first check your building code to see what it mandates as far as separation, slope and sills between the garage and house. For the reasons I mentioned there should be a difference between the height of the garage and house slabs. If the code doesn't prescribe a certain height, I'd use three inches.
Recent Questions and Replies
