Foundation finishing over exterior Comfortboard insulation
Hello all, we are working on a plan to cover the 1-3feet of exposed exterior insulation on the foundation between the soil level and the start of our siding (I say 1-3 feet as it’s 1 foot on the north wall, and the west wall has a slope so the exposed portion is up to 3 feet on the lower end of the grade). We are considering to use the ‘belt and suspenders’ approach described by GBA member Riversong (see post from 2010://m.etiketa4.com/question/question-about-finish-over-exterior-foundation-insulation#comment-105581).
He describes using surface-bonding cement over metal lathe / 1/2″ hardware cloth to cover the exposed, above grade portion of exterior insulation. In our case, the insulation product we’ve used is the semi-rigid Rockwool Comfortboard 80 not rigid foam. Our local contractors supply guys have cautioned about the cementitious coating over Rockwool due to moisture issues – they fear that there could be efflorescence over time on the cement coating.
I wonder if anyone has applied a cementitious coating over Comfortboard before, or has any other suggestions. We wondered about installing a vapour/air barrier between the Comfortboard and the metal lath for exampe to stop/slow moisture transfer to the cement coating for example?
(Note: we are in Eastern Ontario, climate zone 6)
Thanks so much for any comments, tips or suggestions.
