山墙和山脊通风口文学
你好,
我应该用山墙安装山脊,没有任何拱门或其他屋檐通风吗?阁楼空间目前在每一端(没有风扇或其他有效)的山墙通风口排出。这所房子是唱片式/谷仓风格/荷兰殖民地,所以2楼还有朴实的屋顶瓦。没有连接两个区域(陡峭的2楼和逐渐逐渐阁楼),保存两者之间的任何框架间隙。
I am looking to replace my roof and the contractors I received quotes from all want to install a ridge vent, but no soffits (since there is no traditional place to install). One did specify the ridge vent would be an external baffle unit, but the others were vague as to what would be installed.
I have seen some of the options for sheathing-mounted venting options, but have not found any contractors familiar with the product.
山墙脊通风组合是否有文献?我已经看过很多关于通风的文章,但如果这种组合是一个改善/损害,那么与山墙通风口相比,没有什么?
房子位于4A区,距离华盛顿特区北部和巴尔的摩南部。
我是该网站的长期读者,并且在为摘要文章编制的响应中一直印象深刻。
Thanks.
GBA详细资料库
在您的阁楼里是否存在和水分问题(例如护套上的模具)?如果您的阁楼干燥,请不要担心。
阁楼通风是一个被高估的措施。的ories expressed on building sites about the value of attic ventilation are based on opinions and old stories, not science.
如果您想防止阁楼水分问题,您可以采取的最重要的一步是减少通过天花板的空气泄漏。
Martin,
不,没有明显的水分问题。[没有霉菌,模具或下垂的护套。只是一些深褐色的桁架让人想起更彻底的暴露的极端热量。]
通过你的陈述,它是正确的,添加了山脊发泄既不提供福利,也不损害吗?从“舒适”或“节能”的角度来看,我同意你的看法。阁楼温度不会影响条件包络。这个参数是否扩展到沥青瓦片性能/耐用性?
我已经填紧了所有的天花板,并为阁楼舱口盖上密封盖,但这些盖子只有大约一年的房子的一部分。绝缘最小/原始R19玻璃纤维BATTS和该计划是在屋顶完成后通过吹入绝缘材料来补充。然而,这意味着这些年来,屋顶已经部分地调节了屋顶的温度极端(通过泄漏调节空气)。密封所有这些泄漏的空气似乎很好,但这改变了阁楼的动态,我无法判断我是便士(最小化持续/可变成本),但笨拙(通过减少屋顶的寿命增加资本支出)。
谢谢。
Q. "Is it correct that the addition of a ridge vent would provide neither benefit nor impairment?"
答:如果我是你,我会与新的屋顶工作一起安装山脊。它很容易做到,不花所得很多,并且可以提供一些小利的好处。
Q. "Attic temperature will not affect the conditioned envelope. Does this argument extend to asphalt shingle performance/durability?"
A. Studies of asphalt shingle longevity are hard to conduct, but it's safe to assume that temperature affects shingle durability to some extent. There are two twists to this issue: attic ventilation doesn't lower roof sheathing temperatures as much as ventilation advocates assume; and the color of the shingles and the orientation of the roof matter far more (when it comes to shingle temperature) than the presence or absence of attic venting.
您无法更改屋顶的方向,但您可以选择瓦片的颜色。如果您想要更酷,持久的带状疱疹,请选择白色带状疱疹。无论如何,无论你选择的瓦片的颜色如何,我都不会担心阁楼通风。
您似乎是假设您的天花板在过去几年中如此泄漏,您的空调系统如此强大,夏季期间泄漏的酷空气可能一直是空调您的阁楼和降低屋顶护套温度。我觉得这个理论远远而不太可能。虽然天花板泄漏肯定提高了您的能源账单,但逃逸的凉爽空气不太可能是显着冷却您的屋顶护套。
