为小浴室加热?
mlmaggie|Posted inEnergy Efficiency and Durabilityon
我正在翻新房屋,安装太阳能电池板,摆脱强迫热空气系统,并用迷你切片替换(非常小的房屋<1000平方英尺),我想在浴室中安装一个节能加热系统(大约6个)′ x 8′) as I’m not sure the heat will effectively get there, plus I like to have a separate zone for the bath for the usual reasons. i had thought about electric radiant heat in the floor but have heard that can be quite an energy drain. Do people have a suggestion for a very small heating unit for this purpose? Thanks! Maggie
GBA细节库
由气候和房屋部分组织的一千个建筑细节的集合
搜索和下载施工详细信息
在您使用浴室之前,将电动地板运行一个小时,就是多少个月度费用。
迷你将完成其余的工作。
开始建造。
You can also use a vent fan that has a heater built in. It will prob be an energy hog, but will only get used when you need it, and its hard to beat stepping out of the shower into a hot stream of air
劣质煤, most or all of your choices are going to be direct electrical resistance heat, including the heated mat under tile, fan with built in heater, heat lamp, electric radiator or Cadet heater, etc. As such, they're all around 100% efficient, and none of them is more of an "energy drain" than any other. Personally, I wonder if a lot of the heat generated by a vent fan/heater combo just gets sucked out by the fan, but that's just a hunch. I would go with the heated tile or possibly something like a Convectair electric radiator on the wall (or maybe one of their towel warmers). Get a programmable thermostat for it.
AJ, it seems like you now say "start building" or "I'm ordering concrete" when you feel you have given the definitive answer and no further discussion should take place. If you start your own web forum, you'll be able to close discussions as soon as you feel they've run their course. Here... not so much.
I put a fan/light combo unit in a small, well-insulated bath. During the winter, I put a heat lamp in the unit, so when the light was turned on, the heat lamp heated up the toilet seat or the person sitting on the toilet. Radiant heat is comfortable. Worked great and didn't use much energy, since it was only on when someone turned on that light. I had other lights over the sink for general lighting, and replaced the heat lamp with a regular light bulb during the warmer months. The fan/light combo unit would automatically turn on the fan if it overheated, which I guess is possible if someone left the heat lamp on long enough.
您的浴室绝缘够好吗?您是否通过窗户获得了很多不必要的空气渗透?长期最便宜的解决方案是增加绝缘材料。绝缘材料不会产生水电费,或者如果安装得当,几十年来需要维护或更换。
Best of luck with your projects!
没有混凝土,请使用Thinset放置电动哑光系统。
构建它。
大卫建立了一些东西。我的男人更有生产力地利用您的时间。
真正欣赏输入。大卫,感谢您的所有意见和想法。这很有帮助。而且我认为可编程的恒温器是我们试图实现的目标。如果我们在冬天不在一段时间里,我们希望能够将加热区域限制在浴室/厨房/洗衣区...
我们之前已经有辐射的地板加热(但这是H20),当恒温器更换时,花了很长时间才能达到温度。我们被告知基本上是一个系统,您选择了温度并将其保留在那里,因为它的响应时间如此缓慢。没有将恒温器降低过夜并在上午再次提高,所以我很惊讶地阅读您的评论AJ来运行一个小时。这是因为它是一个相对较小的空间,还是电辐射热比H2O更快?
还有罗伯特(Robert),它已经非常隔热了,在翻新期间,我们在新壁板下添加了2英寸刚性的隔热材料。窗户是新的,并且像窗户运行一样有效。因此,是的,一般的房子更好比大多数人隔热 - 我们的目标是尽可能接近零能量设计。
我会检查辐射,Convectair系统和as an adjunct, the heat lamp... would putting the heat lamp with one of those other systems be overkill? if anyone has any other ideas i'd love to hear them. work will not begin in earnest until the summer so there's time to make an informed decision.
玛姬,我对电加热瓷砖浴室有第一手知识。业主喜欢它。他们通过随附的计时器打开地板,并随附其首选温度。试用和错误弄清楚进入AM的浴室之前打开的时间。
它运行1000瓦,一个小时的价格为每月5.00美元。他们在最温暖的月份不使用它。
我对我的其他解决方案还不错,但不那么高,实际上,有些想法对我来说并不理想,例如粉丝奔跑的经文沉默。
I have used heat lamps myself. They are low cost and work well for the body. They do nothing for the toes and the floor.
最后,这是一个选择。就那么简单。
Choose and build. David, smile my man.... you'll have a better day.
