在双螺柱壁上通过顶板ZIP与intelo的连续空气密封初级空气屏障的重要性
吉姆·霍金斯|发布了能源效率和耐用性在
我在安大略省有一个正在建造的新家-气候区6。两层,1400平方米。每英尺。较低的一层是步行地下室,三面ICF墙。框墙是(从外到内):工程木搭接壁板,1×4垂直条带,½“拉链护套,结构2×6墙,1”间隙,2×4内墙,Pro Clima Intello Plus蒸汽减振器,½“干墙。屋顶主要是通风阁楼的平天花板与18“能源脚跟桁架。天花板(从内到外):½”干墙,1×3捆扎,Intello Plus,桁架。天花板和螺柱墙绝缘是吹入玻璃纤维。外墙的拉链护套和天花板的Intello Plus形成了主要的空气屏障。我的问题是:连接外部空气屏障(Zip)到天花板的Intello的双螺柱墙顶部板的空气密封有多重要? I think this is very important, but I’m not sure my builder is convinced. Otherwise, if there are any air leaks in the Intello in the walls – not unlikely given the numerous penetrations for wiring, etc., and the Intello location immediately behind the drywall where it is susceptible to damage from nails, screws, and the like — that air has a path through the insulation into the unconditioned attic space via the 1” gap between the top plates of the stud walls. This seems like a recipe for moisture condensation problems as well as energy loss during the heating season. Most of the high-efficiency building documentation I have seen emphasizes the need to carefully air seal the top-plate area. It could be argued that well-sealed Intello in the walls could be the primary air barrier, but I’m reluctant to rely on it completely. One of the reasons we paid a premium price for the Zip was to make it the primary air barrier. Thoughts? Am I being totally nit picky?
谢谢你,吉姆。霍金斯
    马尔科姆·泰勒||#1
    吉姆,
    答案很简单,你需要一个连续的空气屏障。如果是墙壁上的护套和天花板上的Intello,那两者肯定是相连的。
    我怀疑你的建筑师正在将墙壁上的Intello详细说明作为主要的空中障碍,因为它们用于与Poly做出的,而那就是封闭率来自的地方。
    您的图纸专门调出邮政局作为主要空中障碍,并要求它详细说明吗?如果是这种情况,有许多其他交叉路口(窗台,开口)需要不同地处理。
    1. 吉姆·霍金斯||#2
      马尔科姆,
      非常感谢您的及时回复。极大的帮助!不幸的是,施工图纸没有提供详细的细节,所以存在一些不确定性。这确实显示了业主、建设者和任何参与项目的能源顾问之间持续和开放的沟通的重要性。
      吉姆
