GBA标志水平 Facebook LinkedIn Email Pinterest 推特 Instagram. YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon Audio Play Icon 耳机图标 Plus Icon Minus Icon 检查图标 打印图标 Picture icon 单箭头图标 Double Arrow Icon Hamburger Icon TV Icon Close Icon Sorted 汉堡/搜索图标
社区and Q&A
在车间屋顶上安排刚性泡沫
CZ 4A_GIOVANNI S.|发布了GBA Pro Help在
hello, I am in 4a climate…
刚性泡沫安装最佳布置所需的提示......
由于凝结问题,需要完成天花板绝缘的适当底部..并将空气通道添加到4/12倾斜的谷仓屋顶。
布局…
Top layer….Painted steel Ribbed roofing sheets
下一层:固定在1×4板条上
下一层:将其固定在2×4椽子上
(planned) next…narrow end of another 2×4 fastened atop original 2×4…Allowing 7 inches.
这......为了提供1.5的空气通道间隙(抵靠金属下侧)的空间,在毛茸茸的下面的毛茸茸的下降和更多的刚性绝缘空间。
I already have in my possession (donated free) XPS (2in & 1in) foam and PolyIso (foil faced) 1/2 in sheets. I understand that i dont need a vapor barrier…but it seems i have some materials that operate as vapor barriers ( PolyIso) and Vapor retarder (XPS).
排列这些床单的最佳方式是什么,而不是在吊顶绝缘的小型大教堂中捕获水分?如果可能的话,也许有助于热桥接?我需要获得不同的绝缘吗?(顺便说一下,成品的天花板将是6英寸舌头和沟槽松板,我也廉价地收到。)
(Uses of stucture: Involves high moisture activities, canning etc…and heated in winter, either electric, double split, or mr buddy propane. Stucture will have frequent use.)
So, essentially, can i make the system work with the materials i have? And if so, the best arrangement? Thanks much
Giovanni
加入建设科学专家的领先社区
  1. GBA Editor
    Brian Pontolilo||#1
    Hi Giovanni.
    只是为了清晰,没有护套或屋顶界定。那是对的吗?
    1x4s垂直于椽子运行。那是对的吗?
    1. CZ 4A_GIOVANNI S.||#2
      是的,就是这种情况。perpindicular。
      1. GBA Editor
        Brian Pontolilo||#3
        I'm always reluctant to say to much about atypical buildings in design, construction, and use. But if you treat this like a vented, insulated cathedral ceiling, you could use some of the rigid foam to make vent baffles between the rafters, then fill the cavity with fibrous insulation for R-value, then use more rigid foam, continuous along the underside of the rafters to mitigate thermal bridging.
        In this arrangement and your climate and given the high-humidity activities you plan to do in the workshop, I think you'd want to make the ventilation baffles from the most vapor-permeable material you can, maybe EPS foam, and use the more vapor-closed rigid foam for the continuous insulation. In this way, you'll have a warm-side vapor retarder and an assembly that dries to the outside.
        您应该做一个无可挑剔的作业空气,密封装配的内侧。您可以用填缝,密封胶和胶带安装连续的刚性泡沫空气。如果您不安装连续内部刚性泡沫,请在舌头和槽顶板上安装气密干墙式天花板(镶板不会空气紧密)。在这些活动期间,使用除湿器或减压建筑物的湿度(您可以简单地将盒子风扇放在窗户中,例如在罐头期间吹风。
        再次,因为这不是一个常见的情况,我对这种方法并不是积极的,希望如果任何其他的gbaers都有像你的建筑物/用途的经验,他们会颂扬。
        1. CZ 4A_GIOVANNI S.||#4
          Brian,
          thanx much for your insights, on helping me think through this. Totally understand your initial reluctantcy, but any and all insights will help me think through the various options.
          Been a huge fan of the siga sicrall tape, and likely will use it for air sealing in this scenario.
          Any more thoughts, confirmations, etc. would be great as ya'll have time. many thx
          Giovanni
        2. CZ 4A_GIOVANNI S.||#5
          Btw, say i obtain the EPS board foam, to dry to the outside, is a thinner piece advisable, say a 1 in verses a 2 in of the EPS, (since the thickness can affect density, and thus permeability/or permeance...before i layer a fibrous insulation for example...)
          或者换句话说,更简单地......夹层层的比例应该是较高的渗透率,以最低的最低渗透性?如果我基本上在内部椽子内有5英寸......在空中通道之后......说,也许是2.0英寸的材料,具有最高渗透性面向向外的,其余3.0英寸内部最少的内部内部?或者更像1到4英寸的比例......类似地工作?
          ( i do realize i am limited in making this a VERY cosy place, due to lower R-levels in gen). My idea is do my best to seal internally while preventing trapped moisture from foolish decisions on my part).
          1. GBA Editor
            Brian Pontolilo||#7
            You are correct that the thicker the rigid foam the less permeable. In the case of the site-made ventilation baffles, use as thin of material as you can that won't deform. Seal it in place with caulk, sealant, canned spray foam, and/or tape. This way you will promote proper ventilation and maximize drying potential.
  2. 沃尔特Ahlgrim||#6
    Of course you will cover the foam with something with a 1 hour fire rating as require by code? If for any reason there will be no inspection making you cover the foam, I say you would be crazy not to as the fire rating will give you the time needed to escape before the fumes from burning foam kill you.
    请务必找到并阅读Martin关于如何隔离杆谷仓的文章。
    In my opinion every cent you saved and more by building a barn will be spent in a failed effort to make it be a high performance house.
    Walta
    1. GBA Editor
      Brian Pontolilo||#8
      Here is the article on how to insulate a Pole Barn:如何隔离杆谷仓
  3. CZ 4A_GIOVANNI S.||#9
    Brian,Yup,看过一些各种谷仓文章。良好的指导。我怀疑自从我的情况有点略有不同的条件,而且我认为这种理想的材料......(渗透率范围......)特别是在4A中,我无法确定必然是一个理想的行动方式。(我有点太细节导向,但不一定是完美主义者)。不同的观点帮助。
  4. CZ 4A_GIOVANNI S.||#10
    Any more tips or suggestions from the Pro's?
