湖边小屋潮湿问题-水牛板软
waggatail|发布绿色建筑技术在
我们买了一间在20世纪90年代建造的机舱,有一些水牛板,如纤维板,作为壁板护套和重型粗糙的木材。打开墙壁以放入新窗口时,我发现了纤维板。The place has this mild, faint odor that is more like damp paper than mold or mildew, but possibly some mildew mixed in. When the windows are open it’s not even detectable but I have a super sensitive smeller and it annoys me after awhile when it’s cold out and we close up the windows. When you push on the board, it is soft, slightly mushy but not degrading. I’ve read that this stuff is supposed to be good for dealing with moisture, supposedly doesn’t support mold, and that it will dry out but in the lakeside environment it seems like it never really does, so I think that this is what the smell comes from. I’ve noticed the smell is mostly in the part of the structure where the buffalo board is used, where the older part of the cabin probably does not have it, is completely different, and much less of that smell migrates over to it. Being 50 feet from a lakeshore and on soil that must have a pretty high water table (in Wisconsin) there is so much vapor rising up into the space between the sheathing and the siding, when I reach in along the bottom edge outside it is actually wet except during the late winter into late March, when the air has been much drier than the rest of the year, even right after a lot of snow has been on the ground under it and melted away. I considered that maybe the plumbing was leaking inside the wall but the plumbing is still winterized, well pump turned off for the winter and not back on again but it’s getting wet again now. There is supposed to be a little gap between the sheathing and the siding so water can run down and out, but the vapor does seem to be likely to be all coming from below and getting trapped right in between. Inside the wall cavity there is fiberglass batting with a proper vapor barrier between it and the drywall. But I pulled a lot of it out of the several joists where the drywall is opened up and not too much sign of mold but some spots or specks where it MIGHT be minimal mold, might be just some insects got in right around the old window and nested and died. What would you do?
    Waggatail,
    我给你提个醒,提个建议。在房子里安装几个低成本的湿度调节器,开始跟踪你的室内湿度。听起来你的水平很高,但数据总比猜测好。
    我对你的基金会也很好奇。是地下室,爬行空间,还是别的什么?
    阿尔卑斯山脉||#2
    侧板后面有WRB吗?一些纤维板被评为WRB,它只是不是非常有效的一个。取决于壁板的细节,它可能会让大量的水进入,导致问题。
    像这样的季节性小屋的另一个问题是,尤其是在阴凉的情况下,室内温度会下降到接近露点,造成室内非常潮湿的环境。如果是这种情况,你需要在这个地方运行一个除湿器或加热一点。一般要避免室内RH超过60%。
