高效壁炉的化妆空气
更聪明|发布一般的问题上
阅读本文和所有评论后,//m.etiketa4.com/article/how-to-provide-makeup-air-for-a-wood-------,我现在非常关心安装在我的壁炉上的化妆通风口,这是一个连接到右下角的4英寸通风孔(请参阅图片)。我认为壁炉上的阻尼器基本上是关闭/打开该通风口,但事实并非如此,现在听到这可能是火灾危险,而壁炉确实只需要15-25 CFM,我想我会断开它的连接……
My new house will be very, very tight (still need to have the blower door test), I’m thinking of converting this vent as a hood range makeup air with a motorized damper and inline fan, controlled by a sensor on the range chimney. I know 4″ will not provide a lot of CFM but not intending to have a powerful hood range either. The fireplace is maybe 15 feet away from the hood range. Do you think this is a good idea? What about using the same makeup air vent for the dryer (I get I could not use both the dryer and range hood at the same time)? Maybe also add a switch nearby the fireplace to open the damper just to provide some makeup air when starting a fire instead of opening a window? Any expert opinions are welcome!
    马尔科姆·泰勒(Malcolm Taylor)||#1
    斯蒂芬,
    在断开该空气进气的连接之前,请检查制造商的说明和建筑代码的适用部分。这样做可能是不合法的。
  2. 更聪明||#2
    马尔科姆,好问题:
    - 进气口不是我们建筑法规的要求
    - 制造商安装文件说,新鲜进气套件是可选的(https://www.occanada.com/us/en/heaters/high-efficicy-fireplaces/vb00018/)
登录或创建一个帐户以发布答案。
最近的问题和答复
