Cost to Install Multisplit for HVAC
Just started getting back some bids for a new home we’re building in MA (Boston suburb). I’m worried because although we are shooting for “pretty good house” insulation levels, some of the builders expressed skepticism of using a mini/multi-split for HVAC. On our first bid, they indicated that a mitsubishi system would cost $88k to install, and it just sounds outlandish given my early research into the systems! Is this one of the “non-bids” that I hear about – where an HVAC contractor puts in a high price to sway you away from these systems and back towards traditional gas furnaces?
这是一个3000平方英尺的两个故事。Beopt和Coolcalc#在35,000 BTU热负载范围内返回(仍在进行官方的工程负荷计算中)。我应该寻找自己的HVAC安装程序,还是要认真低估了我的目的?
GBA细节库
由气候和房屋部分组织的一千个建筑细节的集合
That sounds insane. We're in MA as well.
我们使用了Boucher(https://boucherenergy.com/) to replace our AC with a Mitsubishi heat pump system last year. The project was around $37k for a MXZ-8c48NAHZ outdoor unit, with a SVZ-KP30NA andSVZ-KP24NA ducted air handlers, and MSZ-GL06NA head. The project also included completely replacing our attic duct work, and Aerosealing all of the other duct work. We also had hydro heating coils installed in the 2 air handlers for backup from our existing boiler.
Boucher was able to get us into the MA MVP program, which covered around $5K of the system. We also tried to get the DOER heat pump generation credits, but were ineligible because the 8c48NAHZ doesn't meet the requirements. The 42k would have, in hindsight.
It was a big project and less than half your bid.
If you're only doing ductless heads, you should also talk tohttps://www.netrinc.com/
@Jeff-我很高兴能在您强烈推荐后跟进Boucher。
他们只是以75k的价格回到我身边!他们想将3个单独的室外装置放入带有3个管道的空气处理程序的室外单元 - 因此,从本质上讲,您可以用另一个处理程序+管道将头交换。我什至问过要使用一个多区域与3个冷凝器一起使用,但我的代表表明,价格不会有太大影响!
I'm even more confused about pricing now!
Sound like a bait and switch bid with a head in every room and the compressors over sized by at least 3X.
Consider having the engineer prepare the head size and placement and compressor specifications. For the contractor to bid. This way the contractor is not going the oversize every thing to cover his tail.
Walta
对我来说听起来很高。我在新泽西州的郊区,收到了3个报价,用于新的建筑安装,加热负载为50,000 BTU。安装的设置为5个室外单元和6个室内单元。二楼和未通风的阁楼由2个管道的中型静态富士图12RGLX提供。其他单元是壁挂式安装座。总安装成本不到5万美元。具有类似设置的Daiken报价约为55,000美元,三菱报价约为65,000美元。
It's either a bad quote, or a bad system design. Ask them for a list of installed equipment to help figure it out.
I’m blown away by these prices. I know cost of living is higher in the Northeast than the rural South but today we paid $6k for a Fujitsu system with 4 indoor units and 2 outdoor.
Currently soliciting bids to replace our aging furnace with a multi-split heat pump with a mix of ducted and ductless units in a two or three zone configuration. Our house here in Tacoma (not a cheap labor market) is smaller than yours (~1800 sq ft of conditioned space) but roughly the same heating load. I've had a range of bids from ~$18K - $28K, some of those have included total duct replacement, others partial replacement.
That bid is insane. I would not deal with any company that proposed that.
The other bids in the $30k range sound insane, and the $18k-$28k range also sounds very high.
在东南部,您可以在新建筑中安装一个标准的拆分系统,价格约为5k- $ 6k。假设新房屋中2个系统的HVAC成本为12,000美元。即使迷你平台系统仅花费两倍,它也永远不会为自己付费。
I hope someone in the trade with familiarity around this pricing responds to this thread, as I cannot understand why minisplit install costs are so insane. I'd like to know which of the below is incorrect:
一个。设备成本等于或低于传统分配系统
b。AUX材料成本(管道等)要么较小(非管道系统),要么是因为传统系统使用flex and ducted mini的需求硬管。
C。安装更容易(更轻,较小的室内装备)
d. Commissioning is a bit more (more complex controls, less room for error on charging the system)
请记住,我们的3.7万美元估计包括大量管道和航空销售。由于我们是双燃料系统,因此我们需要锅炉工作。
In the north, before mini splits, the only AC option for older houses with rads was high velocity. These are not cheap, so when mini splits came in, installers started offering them as an alternative. The price never reflected the real cost, as long as it was cheaper than high velocity, people bought them. Thus the silly prices.
Usually you can find much better pricing if you only cost the install of the unit and the ducting is done by others. This would get you a closer to realistic parts+labor cost instead of magical pricing.
感谢所有的输入人,很高兴知道我对看到数字并不疯狂!
我也非常感谢这里专门研究这些系统的一些本地安装程序的提示。我要与他们联系,因为看来我必须是驱动这个特殊角度的人。我们联系的建筑商具有出色的工艺,但都是更传统的同类工艺。我知道他们最初对我想拥有的系统类型的最初规范犹豫不决,因此从这个意义上讲,这并不奇怪。不过,也许有些失望!
The price is insane. I'm also in the Boston area. I've got a similar size job being done for about half that (ducted Mitsubishi cold climate heat pumps with three air handlers).
@wooba。谁在做这份工作?目前,现在在波士顿以外的1915年平房中获取报价。在这里给出建议,我首先要有一个绝缘子执行鼓风机的门测试,以确定需要做什么才能进行绝缘。接下来,我将获得第三方HVAC设计。关于波士顿地区HVAC设计师的任何建议,用于改造热泵吗?也许,达娜可能会在这个问题上权衡。
I can't offer a 'designer', but Boucher (mentioned above) was the only contractor I found that did a solid, reasonable load calc and system design.
杰夫,刚刚为他们报价。他们似乎对我的小斗篷过大。我对他们有些不知所措,但听到了其他所有人的好消息。
Unfortunately, it sounds like this thread has died! I also reached out to Boucher, but they seemed to be oversizing as well. Not to mention, their price was still super expensive (in the 70-80k range). Have you gotten quotes from anyone else?
你与谁打交道?总是有可能就负载计算进行对话。确保设计温度(室外和室内)是准确的,并查看有关该空间的数据并查看降落在哪里。
Did they say why they oversized?
我的报价是37,000美元。他们说,他们不会为我提供手册J,只是一句话。他们将2 9KBTU单元放在我楼上的2间卧室中,这些卧室位于1.5级的斗篷中,带有倾斜的天花板。我的猜测是,有2个6KBTU墙单元1:1带有室外单元的良好倒闭将足够。除非我能找到一种方法来登楼。我真的需要一个经验丰富的评估者或类似的人来看我的房子,并考虑一切。
We worked with Fleming Lund (https://www.infrareddiagnostic.com) to do a blower door/IR audit of the house before we started. He does do HERS rating.
谢谢杰夫,我现在使用鼓风机门的家伙too who will do some smoke guided airsealing for me who works with Byggmeister. I guess I don’t necessarily need the HERS rating but rather someone to look at the big picture of insulation steps going forward and manual J, S and D (if it makes sense) a long with the ability to add ventilation down the road.
