Sharing the radon stack
I have a 4″ PVC stack going from below the slab and through the roof to provide passive ventilation of radon from below the slab (potential radon—not yet measured). Is there any reason I can’t tie into it with the bathroom ventilation duct? I like minimizing roof penetrations.
The duct would tie to a Y that points upward; between that, the draft created by the stack itself, and the damper on the fan, I see no risk of ozone entering the house. Any problems?
Thanks.
So what happens if you have to add a vent fan to your radon system? Then you'll be depressurizing your home 24/7.
There are probably code issues as well.
David,
Steve accurately identified the two relevant issues: (1) Your plan would violate plumbing codes, and (2) Your plan would make it impossible to convert your passive radon mitigation system into an active radon mitigation system.
