GBA Logo horizontal Facebook LinkedIn Email Pinterest 推特 Instagram YouTube Icon Navigation Search Icon Main Search Icon Video Play Icon Plus Icon Minus Icon Picture icon Hamburger Icon Close Icon Sorted
社区and Q&A
在4区喷雾泡沫和减湿问题
Matthew Wahlrab|发布Passivhaus上
I am remodeling a home outside of Seattle, WA. I plan on spray foaming the existing 2×4 exterior walls with closed cell spray foam (looking for R-24) and plan to frame out a new interior wall (probably 2×3).
我想在现有的外墙和新内墙之间的缝隙中安装一个2英寸的聚异透明板,以在我的外部墙螺柱的脸上添加连续的R-13。聚异氰尿素将被填充到螺柱上,彼此,关节将被粘贴。
我担心墙壁内部收集水分。关于管理进入墙内内部的水分的任何技巧或建议吗?我渴望使自己的家用空气紧密,隔热,杀死附近繁忙的街道,并避免在墙内种植一个漂亮的模具农场。
  1. GBA Editor
    Martin Holladay||#1
    马修,
    如果您在螺柱托架中安装闭孔喷雾泡沫,以及在螺柱内部连续的polyiso层,只要您拥有良好的外部闪光和水管理细节,墙壁护套和螺柱可能会保持干燥。这种类型的壁只能干燥到外部,因此它将受益于通风的降雨间隙。
    That said, there are lots of ways to build a wall. It sounds like you want to build a double-stud wall -- is that correct? Were you planning to insulate between the studs of the new 2x3 wall? Most double-stud walls are insulated with dense-packed cellulose, not spray foam. (Many green builders try to limit their use of closed-cell spray foam because most brands of closed-cell spray foam use a blowing agent with a high global warming potential.)
    For more information, seeHow to Design a Wall。
  2. D Dorsett||#2
    Closed cell foam installed in 2x4 framing 16" o.c. is a waste of good foam (at a high envrionmental & financial cost), due to the thermal bridging of the 25% frmaing fraction. Even though you would have a center-cavity R north of 20, after factoring in the thermal bridging it only adds about R1 to the "whole wall-R" perforamance beyond the same wall with ~R13 half-pound density open cell foam that uses 1/4 the polymer, and water as the blowing agent instead of climate-damaging HFC245fa (with a global warming potential of about 1000x CO2).
    仅在0.5磅的泡沫腔填充上,将仅1/4英寸添加1/4英寸,将超过2磅泡沫的性能增长,并在较大的环境击中。使用1磅polyiso(而不是1.5-2磅的屋顶polyiso)使用一半的聚合物每R的2磅闭合细胞泡沫,并用戊烷吹,其GWP约为7倍CO2。
    With 2" polyiso (all facer types) in the middle of the assembly, the exterior studs & sheathing will have to dry toward the exterior, and the interior needs to dry toward the interior. The interiror studs will not have an issue- there is PLENTY of exterior R for keeping those materials above the ~45F interior air dew point in that climate. But the siding type , roof overhangs, and flashing details will determine how dry the structural sheathing remains.
    在美国气候4的位置,可以使用PV阵列以大约R20-R25的全壁表演在房屋上击中净零能量。请参阅本文档的表2,第10页:
    https://buildingscience.com/sites/default/files/migrate/pdf/ba-1005_high%20r-value_walls_walls_case_study.pdf
    在2010年,当它写得更好的无管热泵时,HSPF的HSPF约为10-13-13,而高输出光伏太阳能(PV)的效率约为15%,现在运行量约为20%。屋顶光伏的价格也约为2-2.5倍。2016年的价格。典型的2x4/R13墙,具有典型的壁板和室内装饰选项的全壁约为R10。即使没有内部螺柱,添加连续的R13(Polyiso的2英寸)即使在R20的北部也使其在R20中的北部。在某个时候,与安装屋顶PV(甚至在西雅图脱落的西雅图)或将钱投入其他物品(例如基础隔热等)相比,它不再具有财务意义表2.该文件的墙壁而不是越来越多的墙。在那个索赔中,我自己的倾斜度将是2x4s和2“ polyiso的开放式细胞泡沫(或3磅+密度纤维素),将石膏直接粘合并长期拧紧到Polyiso,跳过室内螺柱。
    在许多地方,有二手屋面多丽莎的供应商(通常是2磅密度,r5.5/英寸),占原始库存商品的一小部分。在我的地区,在您所在地区的2英寸厚屋顶ISO的2英寸厚屋顶ISO的回收4x8张(显然在您所在的地区也大约相同的每平方英尺):https://seattle.craigslist.org/sno/mat/5937828295.html) Reclaimed/reused foam (any type) is by far greener than any virgin stock, since the environmental hit has already been taken, and re-using it is just piling on to the benefit side of the cost-benefit equation.
Recent Questions and Replies
